Balance your BH blades
   / Balance your BH blades #1
RobJ
Elite Member
Spring, TX (Houston)
Kubota L2500
I put my 4' BH on my tractor the other day to use it. Since getting my tractor used I have only used it once (use a FM most of the time). I remember a little shaking but I was cutting crap. But last weekend it seemed to shake a whole bunch. Checked it out and the stump jumper seemes to be bent. My son and I took it all apart and decided to check the blades. Used a simple piece of PVC with a hole in the middle, a bungy cord in the center hole and the bungy hanging from the garage door. Hanging the 2 blades it was off a bit but not enough to tip the scales all the way, one side just 2-3 inches lower. We switched sides to double check the scale. I ended up taking only about 1/4" off one blade but what a difference. You could barely tell it was spinning. Sweet! So a little does make a big difference.
Rob
   / Balance your BH blades #2
Rob
You may be getting 250 G's or more when spinning up those long blades. Say the imbalance was only .5oz. That could get you 7lbs of wobble!
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A49461)
2000 Trail King...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
