Bail forks for a TC 40 with a 16 la loader?
   / Bail forks for a TC 40 with a 16 la loader? #1
Jeremy63
This is my first post on here. I just found this place and really love everything. So... I have a TC 40 with a 16la loader. I would like to know if there is a way to retrofit bail forks on the bucket or anything like that. It looks as if the bucket would be a lot of work to get off. I'm wondering if any of yall have build or bought anything like this. Thanks for your help
Jeremy
   / Bail forks for a TC 40 with a 16 la loader? #2
Jeremy, the easiest way I've found is to convert an older non-quick attach system to quick attach and then get a quick attach bale spear. The q-a adapter for the loader is about $360 from your NH dealer.
Of course, you will need to have your old bucket converted to quick-attach. You also buy a bucket quick attach plate from your NH dealer. You have a welder cut the old mounts off the bucket and weld the quick-attach adapter onto the bucket. That will be a pretty good job. The plate and the weld job will probably also be $300 to $350. That's still cheaper than buying a new quick-attach bucket that costs $650 just by itself.
Another way to convert the bucket is with a Uni-hitch adapter that pins onto your old bucket. That will also cost about $300. I have one of those, and I wish I'd just have had the weld-on plate done.
Almost anyway you go, you will be spending $650 for the conversion, and you still need to buy a quick-connect bale spear. That's at least another $200, so you are looking at $850 total, but in the process you will have converted your tractor to a full quick-attach loader which can use any Bobcat implement. I think you will never regret it, but if your budget is tight, you might just buy a 3PH bale spear and start saving your money for the loader conversion. /forums/images/graemlins/smile.gif
   / Bail forks for a TC 40 with a 16 la loader? #3
Try this site http://paynesforks.com/
I have had a pair of his forks for 2 yrs on my TC35D and really like them. I would suggest that you only use them if you have a heavy duty bucket. At the site you will also find bale spears and other goodies. Good luck Frank
   / Bail forks for a TC 40 with a 16 la loader? #4
I bought a bail spear at TSC(2000lbs rated) that attaches to the FEL bucket.. but I have to take the tooth bar off. I'm looking at re-designing the hookup so it will go on w/ the tooth bar installed.
I use the bail spear on the bucket.. w/ bail forks on the 3pt so I can carry 2 bails.
Hey.. Welcome to TBN!! /forums/images/graemlins/grin.gif
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
