Rear Finish Mower Bagger for a Rear Finish Mower? Will this work?
   / Bagger for a Rear Finish Mower? Will this work? #1
Neophyte
Platinum Member
ME
John Deere 3320 eHydro with 300CX FEL
Hi All,
I currently have a 3PH 72" REAR-discharge RFM. I like the mower but it sure does leave a mess of grass clippings behind it because I tend to cut the grass when it's a little too long.
I have a small lawn tractor with a bagger but it is much too small for my lawn. Far too many trips to dump the clippings and it clogs up far too often, which is frustrating to the point where I don't use it.
I was pondering the idea of purchasing a 3PH 72" SIDE-discharge RFM along with a cyclone rake or equivalent lawn vacuum/bagger. My thought was to rigid mount the cyclone rake to the top/back of the RFM and run the hose with mower deck adapter to the side-discharge chute.
Would this work well?
Does anyone see any major issues with doing this?
Has anyone ever done something along these lines?
Do any manufactures make anything along these lines? Something that combines a bagger with an RFM?
Thanks for your input in advance.
   / Bagger for a Rear Finish Mower? Will this work? #2
I abandoned the whole bagging concept after years of struggling with a 30" Dixon mower/bagger. The chute would continually plug no matter what I tried. I now use a tow behind lawn sweeper, works great. It has way more capacity then the two bags on the Dixon and can pull it with the Dixon. It is a 42" Agri-fab brand and cost a little over $300. I mow and then sweep. bjr
NEW TELESCOPING 24 FT 4000 PSI PRESSURE WASHER GUN NEW SUPPORT EQUIPMENT (A40019)
NEW TELESCOPING 24...
70in Heavy Duty Dozer Blade (A44391)
70in Heavy Duty...
Towable Generator (A44571)
Towable Generator...
2019 SKYJACK SJ1056 TH TELESCOPIC FORKLIFT (A45046)
2019 SKYJACK...
2013 Bobcat T300 Two Speed Compact Track Loader Skid Steer (A42742)
2013 Bobcat T300...
2003 Dodge Ram 1500 Front Bumper | OEM Replacement | Durable and Ready to Install (A44789)
2003 Dodge Ram...
