Bad starter? Grabbing thoughts before ordering
   / Bad starter? Grabbing thoughts before ordering #1
drunderw
Bronze Member
Greenville, SC
Yanmar 3110D, Kioti NS6010C HST
Hey guys.
I hope everyone had a nice 4th! I put a new solenoid on my starter and although it痴 starting about every third attempt I get the free-wheeling whir sound only
video: Yanmar Tractor Starter Noise - YouTube
Is this indicative of my starter going bad? If so I知 going to grab one of the gear reduction ones from Hoye.
Thanks!
   / Bad starter? Grabbing thoughts before ordering #2
It might also be battery oriented, takes lots of oomph to fling that gear out to engage the flywheel.
Also dry old lubricant on the Bendix can inhibit a good fling, in fact I think dry is better than oiled in this case.
   / Bad starter? Grabbing thoughts before ordering #3
Yup, get the battery load tested properly. My M4700 had the same symptoms, battery appeared to take a charge. Took the battery in to NAPA, the guy load tested it 3 times, it failed twice. New battery and it's started like a top ever since.
Hi- thanks for the replies. I have a new Interstate battery tested there and verified at Autozone back when I was having electrical issues which ended up being the cables from the battery to the starter. Those are all new as well.
   / Bad starter? Grabbing thoughts before ordering #5
Battery sounds strong to me. All the teeth on your flywheel ring gear? I think I would pull it, bench test it, inspect flywheel, etc.
   / Bad starter? Grabbing thoughts before ordering #6
Sounds like a bendix issue. Take it apart, clean the engaging parts in the parts washer and spray with a moly lubricant like Dri-Slide that won't attract gunk. And brighten up any electrical contacts with some emery cloth while everything's apart.
   / Bad starter? Grabbing thoughts before ordering #7
And one thing, if you live near a bigger city they usually still have starter/alternator shops. They can probably rebuild your original for $50 give or take and usually get it back to you in a day or two at most. Some shops can do it that day if not backed up and you ask.
   / Bad starter? Grabbing thoughts before ordering #8
Yup! I agree Clemsonfor. Mine went Dead in 2011. It wouldn't do any thing. Zilch,Nothing and I mean Nodda _ _ mn thing. I had a local Auto Elec. shop repair it. 72$ and some change. Haven't had the first complaint and I use it a lot.
Sweet, awesome idea. I found a place in Greenville that has good reviews so I値l pull it this weekend and take it with me to work Monday to drop it off. Thanks- I値l post an update when I get it back and let you all know what they said and how it goes.
   / Bad starter? Grabbing thoughts before ordering #10
When I had my repair shop I always liked to see starters come in. One of the nice things is that they are small, clean, and most of the time it is the customers who take them off and put them back on. Starters themselves come apart with only a couple of bolts and don't have any gaskets. Most of the problems with starters turn out to be mechanical - like brushes and contacts - rather than electrical failures.
As for repair, not much goes wrong with a starter that can't be fixed inexpensively. Lots can be done right now with nothing more than disassembly, a few universal parts, and good re-assembly.
Starters and carburetors are all a good way for a shop owner to make a hundred bucks after dinner when nobody is in the shop. Generators can be harder.
Little jobs like that are what keep the doors open.
rScotty
2014 Ford Escape (A50324)
2014 Ford Escape...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2015 John Deere...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
Semi Roll-off 2 Axle Trailer (TITLE) (A50774)
Semi Roll-off 2...
More info coming soon! (A50323)
More info coming...
