Tom_Veatch
Platinum Member
Are the regulators on these machines a weak link? I'm replacing the one on my YM2220D for the second time in a year (with less than 20 hours on the last one).
Symptoms were/are:
Symptoms were/are:
- Alternator light is on constantly for any engine RPM from 0 to red line.
- Voltage across the battery terminals is the same (~ 12.5 volts) with or without the engine running. (Verifies no charging current reaching the battery)
- With the engine at about 1200 RPM and the alternator electrically disconnected from the wiring harness, the alternator is showing about 14 VAC. (Verifies the alternator is functional)
- With the alternator disconnected, the resistance between the alternator terminals on the regulator shows 0 ohms. (That don't seem right to me)
- With the alternator plugged into the wiring harness, the alternator wires get uncomfortably hot to the touch very quickly (Indicates a high amperage which seems to verify the alternator is passing current through a low resistance load).
- Voltage from the battery charging current output terminal on the regulator to ground is 0 VDC . (Now, I know that ain't right - should be numerically close to the alternator VAC output.)
