Bad power steering pump on JD 110TLB.
   / Bad power steering pump on JD 110TLB. #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
I've got about 720 hours on my '08 110TLB, now. There's been a hydraulic pump noise since the tractor was new. I figured it would go away with time (break-in) or new filters and/or hyd oil change-out.
Wrong..
Last night, I was parking the tractor in the garage and with crowded quarters, I locked the FEL in the upright position with the loader cylinder block. With the engine running, I stepped out on the front tire to pull the pin and set the block into position on the hyd cylinder. Standing on the tire, I could feel it jerk and shake occasionally every time the pump would chirp.
My local dealer has been giving me the run around about checking it out - telling me it's "normal". I don't agree - especially since it's getting progressively worse. I can now feel the "pulse" or jerk in the steering wheel whenever the pump makes that chirping noise.
Anybody else have this problem with their tractor? Oh yah, my extended warranty is up in April..
Thanks.
AKfish
   / Bad power steering pump on JD 110TLB. #2
AKfish,
Might be the steering valve instead of the pump, the valve may be loading down the pump causing the noise. Since the pump is essentially two gears there isn't much there to have an intermittent problem. I would definately force the issue with the dealer and the John Deere rep.
   / Bad power steering pump on JD 110TLB. #3
AKfish,
I would agree that it's probably the valve...
Thanks, guys. Your analysis of the problem makes alot more sense... It is intermittent! (Sometimes you're too close to really see!) :confused:
I'll let you know how things turn out.
AKfish
UNUSED FOLDING WAGON (A54757)
UNUSED FOLDING...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2018 CATERPILLAR 415F2 IL SKIP LOADER (A52705)
2018 CATERPILLAR...
UNUSED RETRACTABLE AIR HOSE REEL (A54757)
UNUSED RETRACTABLE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
