Bad muffler
   / Bad muffler #1
Dannyleblanc
Kubota M8560
I have a 2013 M8560. The muffler is rotten on top and cracked on the bottom. The dealer wants $700 for an oem replacement. Firstly, do I need to replace it with an oem or is s there an aftermarket option. If I do need to replace with oem how tough of a job is it?
   / Bad muffler #2
The main question is (and I am not familiar with your model tractor) whether there is some kind of interaction with DEF or antipollution device or sensing involved with that muffler. Unless there is some complexity of that nature the second question is "How much do you care what it looks like?" So long as it is simply exhaust gas in and exhaust gas out you can go find any muffler that fits (or almost fits) and adapt it to the tractor. If it is purely a muffler only a blithering idiot, a wealthy one, would pay $700 for a muffler.
Update: I see a photo I took of an M8560 several years ago. It looks like a simple vertically mounted, out in the open muffler. About as simple as they get & very accessible. I'd whack it off and put on a new one in a sensible price range. Being out in the open and exposed as it is it may be worth looking around for something made of heavier/thicker metal.
   / Bad muffler #3
Follow JWR's advice. 2013 was before Tier 4 requirements kicked in so you may be alright. Look the muffler over for sensors and wires then go shopping from there. $700 for a basic muffler seems a bit pricey even for Kubota.
2006 Ford F-150 Crew Cab Pickup Truck (A48081)
2006 Ford F-150...
2011 Terex Fuchs MHL340 Wheeled Material Handler (A49346)
2011 Terex Fuchs...
Tine Weeder (A49251)
2004 Caterpillar 330CL Hydraulic Excavator (A46683)
2004 Caterpillar...
2013 PETERBILT 367 DAYCAB (A48992)
2013 PETERBILT 367...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A45679)
1993 INTERNATIONAL...
