bad dipper cylinder relief valve
/ bad dipper cylinder relief valve #1
chvojka
Hello, I have an old 1965 john deere 2010 tractor with a 93a backhoe on it. all the hydraulics run well but the dipper cylinder will not pull in under power just gravity. it will extend under power. I have figured out it is a bad relief valve in the dipper spool control. The top nut that takes the valve out of the spool valve. I cannot seem to take the valve apart as there is a screw in the end that looks like it was factory set. where would I be able to find a replacement valve probably used as it being 1965 I doubt there many new ones out there?
Any and all suggestions would be appreciated.
Joe
1963 Ford Falcon (A62613)
1963 Ford Falcon...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2023 Kearney 102"x32' Gooseneck Trailer (A64119)
2023 Kearney...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
