Bad day!!!!
   / Bad day!!!! #1
rtsherrod
Fenton, IL
2011 X324; 1970 John Deere 110
Hi all,
A little background first... Yesterday I completed the install of the replacement magneto alternator on my 1970 110. This involved draining the oil and removing the shrouding, flywheel and bearing plate. I cleaned everything up and mounted the bearing plate with the leads routed through and between it and the block with a new gasket. After this I called it a day.
As a side note, the 110 had been converted to a battery ignition at some point and the harness was hacked and mangled. I removed the battery ignition coil and replaced the main harness as well.
Now for today. I installed the batter with new cover and hold-down kit. I put a spare spark plug in the lead to crank it over to check for a spark. I put the key in the ignition switch, grounded the plug and turned the key. The engine didn't crank (PTO was engaged) but I heard a short pop and smoke puffed out from under the shroud.
That's when I realized that I never replaced the ignition switch with one for a magneto ignition. Twelve volts went straight to the primary and smoked it.
I'm going to replace the coil. Should I replace the condenser as well?
Now for the kicker. I disengaged the PTO and turned the key to check for spark, or the lack thereof, and cranked the engine over a couple times, each time for about 15-20 seconds. Then I realized that I forgot to refill the crankcase.
Man was I PO'd. I felt like a complete idiot.
I promptly removed the battery and put it on the charger. I then removed the shroud, grabbed the flywheel and turned. It turned!!! But with some drag. I filled the crankcase and put some oil in the cylinder and turned it over several times by hand to distribute the oil. I still felt drag, but turning it over by hand isn't fast enough to fling the oil around to all of the surfaces anyway.
After this, I'm hoping I didn't cause serious damage cranking it over "dry". Can anyone tell me if I just screwed myself or will I be fine running it this winter?
I'm going to rebuild it next summer and just need reassurance that I will be able to run it to clear snow this winter with little to no worry.
Any input will be greatly appreciated?
Thanks,
Bobby
   / Bad day!!!! #2
Actually your day could have been worse-if your engine had started you would probably be looking at the rebuild now!
Since it didn't start, the film of oil on the bearing surfaces kept you from doing serious damage.
   / Bad day!!!! #3
X 2^^^^
   / Bad day!!!!
Thanks guys for the reassurances.
I have ordered the correct ignition switch and a few other parts through JDParts to be picked up at my local dealer.
I purchased a coil kit off of "that auction site" for about $30.00 less than through the dealer.
Should have everything in time to repair my screw-up this weekend.
Thanks again,
Bobby
2019 JOHN DEERE 325G SKID STEER (A52706)
2019 JOHN DEERE...
20711 (A50323)
20711 (A50323)
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
