bad crome on cylinder rods?
   / bad crome on cylinder rods? #1
schmism
Super Member
Peoria IL
New holland TC(33)
one of my FEL cylinder rods have some fairly bad "flakeing" (for lack of a better word) toward the end of the cylinder rod.
what does one normally do?
wait till it starts wearing out the wipper/seal?
wait till it rusts really bad and pits?
fix it some how?
Replace it? (when?)
   / bad crome on cylinder rods? #2
I wouldn't worry about it til it starts leaking. You could smear some grease on the exposed part and park it with the ram retracted to keep the rust from getting worse. If you use it alot or have a must do job, get it fixed (rechromed) when you aren't going to be useing it so it won't be down when you need it.
fix it some how?
Replace it? (when?)
   / bad crome on cylinder rods? #3
Well, if it's the new tractor in the picture, and under warrantee, I'd have the dealer fix it. If it has an expired warrantee, I would still raise he|| at the dealership. The chrome should not flake off in a matter of a year or two.
jb
   / bad crome on cylinder rods? #4
If it is coming off to where it will get into your hydraulic system, you don't want it to do that. If it gets into your system, you can have a very expensive problem. It can plug valves, passages and spools as well as play havoc in your hydro is you have one. If it is on the shaft outside of the main body or the cylinder, it might not be to bad but I would be afraid that it was flaking inside the body. If it is under warranty take it back to your dealer. If it is out of warranty, take it to a hydraulic shop. A good shop will either rechrome the shaft or they can replace the rod.
   / bad crome on cylinder rods? #5
FWIW...I agree with Jerry. In that case, I'd get it fixed. No sense waiting for the worst to happen....either seal failure or screwed up hydraulic system (or both).
my TC is an 01.... but only 233 hrs....
so ya it only looks a couple years old, but it infact is way out of warntee.
pluss from what i can tell it org had a NH brand loader on it and at some point was taken off and the Rihno put on (for whatever reason)...
Ill snap a pic this weekend
mmmmmmmm pics
farther up the rod is clean
   / bad crome on cylinder rods? #8
Yeah, I'd get that repaired. It will cause premature wiper gland failure and probably an annoying leak sooner or later....probably right when you DON'T need it to happen. (Murphy's law)
   / bad crome on cylinder rods? #9
fix it some how?
Replace it? (when?)
I did not know that hydraulic rods were chromed.
Yours don't look like flaking but pitting. Do you make sure to pull or retract all of your hydraulics for any extended storage. I try to.
   / bad crome on cylinder rods? #10
It looks to me like damage from handling rocks or something. Strange but that does not look like a susceptible location. If its mechanical damage there will probably be some raised spots.
150HP 3 Phase Motor (A53117)
150HP 3 Phase...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2005 Ford E-350 Cargo Van (A51692)
2005 Ford E-350...
