Bad boy mower with Cat Diesel fuel cutoff
   / Bad boy mower with Cat Diesel fuel cutoff #1
Deanes
Bronze Member
NH T2410 55 Hp, FEL and cab
The machine randomly just stops like someone turned the key off. Sometimes it restarts ok, but other times it just cranks and cranks. I have removed and tested the fuel shutoff selenoid. It seems ok when I use a jumper to it from the battery. I suspect it is a wiring problem, but the wires disappear into a big sheathed cable, so I don't know how to find the culprit.
My question is it ok to bypass the wiring system and run a switched line directly from the solenoid to the battery or the key?
Changing parts to find the problem is prohibitive. That little solenoid costs over $600.00!
   / Bad boy mower with Cat Diesel fuel cutoff #2
If it’s a 1 or 2 wire solenoid, yes u can jump it..
If it’s a 3 wire solenoid NO don’t try..
   / Bad boy mower with Cat Diesel fuel cutoff #3
Most fuel shut off solenoids have two coils, the pull-in coil and the hold coil. You need to apply voltage to the hold coil and then hit the pill-in coil with about 1 second of voltage.
Applying voltage to the pill-in coil a time longer than about 10 seconds will cause it to burn out. If you intend to rewire this, you will need two switches. One for the hold coil can be a toggle switch, but he pull-in switch should be a push-button.
If your fuel shut-off solenoid has three wires, one of them is the ground wire. You can use your ohm meter to determine what the wires connect to. The ground wire, usually black, will obviously read about zero ohms between it and the body of the solenoid.
The pill-in coil will have lower resistance than the hold coil.
Richard
2011 John Deere 844K Articulated Wheel Loader (A46683)
2011 John Deere...
Stainless Steel Tailgate Spreader (A49251)
Stainless Steel...
10 LUG ALUMINUM RIM (A48992)
10 LUG ALUMINUM...
2014 Dodge Journey SUV (A46684)
2014 Dodge Journey...
Kubota M5-111 Tractor, Open Rops, Brush Cage  (A47371)
Kubota M5-111...
2016 Ford F-450 Crew Cab Mason Dump Truck (A46683)
2016 Ford F-450...
