backyard sewage problem
   / backyard sewage problem #1
Dutch445
Elite Member
Upstate NY
JD X585
We are getting some sewage odor in the back yard, and now that it is
still wet, I have noticed a few areas where i have standing water, (up in elevation from my own septic area), that are getting that oily greasy look
on top of the water.. making me think somehow I am getting some sewage weeping into my groundwater. The back half of my lot is elevated, and wet, and the previous owner had put in a small (12'x8') pond which is nice for a few frogs. The area around this pond is also wet, and with the recent rains, still quite mucky, as I know there are some springs in this area. I am seeing this discolored water near and in the pond, as well as a small
trench at the back edge of the property that the previous owner dug to try
to divert some of this water off the property.
My question is who do I call to find out where this stuff is coming from?
is it possible that it is runoff from farms up the hill from me? (not within 1/4 mile or so)
Every once in a while, it just smells like good ol sewage, as if somebodys' septic isn't functioning properly.
   / backyard sewage problem #2
When was your own septic system last maintained? Does it have access covers or is it completely buried? Where is this saturated ground in relation to your own drain field? I had a bunch of company this spring and we ran a unch of water thru my septic tank and it stirred up enough particulate matter that it cloged up the screen filter on the tank outlet to the drainfield. Thought my tank might need to be pumped but it isn't realy even 1/4 full of solid material.
   / backyard sewage problem #3
Step one: Find out if your septic system is/has contaminated your groundwater. Have a water test done on your potable water. Make sure the test includes coliform bacteria and nitrates.
Steps 2-?: All depends on step 1. Gitter' Done!
I'll try to explain the layout in words.
Directly behind my house is relatively flat, where the tank and leachfield is.
to the West, my property drops down into some wet swampy areas.
Further behind the house, (south) the yard raises quite a bit to an area where the little pond is. to the east, is the highest of the property. hard to walk up some parts of it. out behind the pond, is another flat area, which is tough to walk thru because of the springs , it's mucky. (last summer i could drive my
garden tractor all over because it was much dryer). I have not noticed any of this condition down in the lower areas of the property, immediately below where my septic and leach areas are. the problem is in the areas that are 5-6 feet in elevation higher than where my septic is. I would guess the depth of the property behind the house is approx 150'.
there is a house to my East, up on the hill, with a large family. The lot between the houses is wooded, and i have never walked up into their yard.
Bordering my back lot is another house, (actually their backyard) with 25' of wooded area seperating our back yards. You can see thru the trees sometimes, but never enough to watch anyone i particular.
I bought this house last summer, about this time. We had all the necessary water tests then, but I have not tested our water since, other than for hardness when the water softener guy put in a new softener 6 weeks ago.
My well is in the front yard, probably 100' from the septic, on the other side of the house,, and somewhat to the uphill side of the property.
   / backyard sewage problem #5
Dutch,
If I drew this out correctly it looks like what you suspect is a sewage leak is UPHILL from your septic system. I would be surprised if that is your sewage. Does the stuff stink? Is it even waste water?
If it is sewage I would be wondering about the house to your south which is uphill from your field and pond. And maybe the house to the ease that is also uphill. Can you find out where their septic fields are located? That should be public information at the county.
Later,
Dan
   / backyard sewage problem #6
Thats what I got out of it as well, possible drain field problem uphill on adjacent property.
   / backyard sewage problem #7
It sounds like from your description. That one of your neighbors has a failed system. Actually, I can't say failed system here because this year has been an extremely wet year. This will cause many systems to flow bad water. The ground is so saturated that it cannot absord all the present water being dumped into it. I tried to mow my lower field yesterday and buried my little 18 horse lawntractor in muck twice. It just sunk in the grass while I was trying to mow. I usually mow this with my 2800 pound tractor with a mid mower. This tells me that we have way too much water this year. I also know that the neighbors system use to do this same thing each spring when the rains and spring thaw came. The black and brown stuff use to pour onto the edge of their driveway.
those were my thoughts as well,, about possible neighbors systems failing.
but, with the amount of water around, it may be compounding even a minor problem. in April, it was dry enough for me to walk and mow up there with my 445, but not since.
So, the question is, who do I call? or do I wait
till some dryer weather comes and see if I still see/smell evidence of it?
yes,, it stinks, faintly, but I guess I am more sensative than some
people.
should I start with a local codes guy? or call the local DEC officer?
I hate to piss off new neighbors, but, would also hate to have my
well water get contaminated also.
   / backyard sewage problem #9
Anytime you get standing water and organics you will have anaerobic bacteria eating the organcs and releasing the stinky methane and septic type odors. The stench isn't necessarily poo at all but just nasty stagnant water and organics. We've all seen the ditches on the side of the road that stay wet and the water actully turns black and stinky even though there is no septic around.
Be very careful about calling the government guys. A failed septic system with surfacing sewage will get the house red tagged and the residents will need to leave. This may be a problem if the gov't guy thinks it is your system that has failed. I wouldn't want to be the guy inviting the gov't to the party.
Who do you call? A septic designer or installer. He will be on your team and very unlikely to report a problem to the gov't. He can also check the condition of your tank.
   / backyard sewage problem #10
Hi Dutch,
As Woodlot suggested, test your water soon, thats something you need to do to protect yourself !!! At that point you can investigate where this bad smelling water is coming from !
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
