Backhoe
   / Backhoe #1
JiminMI
Bronze Member
Fenton, Michigan
L3010HST
Gentlemen, I need some information. I have been shopping for a L3010 with FEL and backhoe. My dealer (the one where I want to buy it) says to eliminate the backhoe pump and resevoir and connect to the fluid lines of the FEL so that the fluids circulate more. He feels that because I may not use the backhoe as much as a commercial person might (probably right), that the fluids will get less condesation and run through the filter more.
My question is this: which is best? My uses are strictly residential. I have faith in the dealer but not in my knowledge on the subject. Everyone on this board seems much more knowlegable than myself but I would like to "do it right the first time"..it's usually cheaper that way.
JiminMI
   / Backhoe #2
Jim,
I bought a 2710 with a backhoe and the general philosophy I got from reading all the notes on this board regarding backhoes was to keep the backhoe fluid and the tractor fluid separate. Any contamination in the hoe's system is independent of the tractor and vice versa.
My $0.02...
Bill
   / Backhoe #3
The backhoe sounds like one that is run from a PTO, rather than the tractor's, hydraulic pump. What is being said sounds reasonable enough. It's true that most tractor pumps, on tractors large enough for the hoes, have enough capacity for the run a hoe. If the tractor pump has enough capacity, I don't suppose it makes much difference to the tractor whether it sits and runs its pump or its PTO. I haven't heard of condensation being a problem in hydraulic systems, but maybe somebody has.
Hydraulic capacity is stated as gallons per minute. The tractor has a pump gpm rating, and the hoe should have operating gmp and pressure recommendations. The dealer should be able to tell you what they are.
A hoe that is operated on less gmp operates slower than may be desired. A hoe that operates on less pressure has less power than speced.
In general, there is little reason to run a hoe from a PTO pump unless the hoe is not well matched to the tractor. A poorly matched hoe may have undesirable operating characteristics, and it would be a good idea to ensure that the tractor hydraulics will run the hoe adequately.
There is another issue. Backhoes are stressful on tractor frames--especially 3ph hoes. Hoes have been known to crack tractor frames in half. A little tractor that has ran a big hoe might not be the best buy unless you are confident in how the big hoe was used.
   / Backhoe #4
There's some info in this thread http://www.tractorbynet.com/cgi-bin...ement&Number=21727&page=0&view=collapsed&sb=5
I think the difference between PTO pump and tractor hydraulics is splitting hairs provided the tractor has enough flow and pressure. Eliminating the PTO pump will same money.
As for 3PH hoes, I'd like to hear about cases where tractor damage has occured with a properly matched/mounted 3PH hoe. I agree that a 3PH makes it possible to attach hoes that are way too big for a tractor, and to attach them without first installing any required reinforcement hardware, and that this can lead to problems. But, overloading/abusing equipment will lead to failures. No surprises there.
If you are going to mount a 3PH hoe, mount one that's sized for the tractor (a Woods 7500 is sized for the 3010), and use the Kubota recommended hardware (Don't know what it is for the 3010, but you can find out by asking what has to be done for the tractor to mount a Kubota 4690, which is their 3PH hoe).
   / Backhoe #5
Bill, I know some folks give the possibility of hydraulic fluid contamination as a reason for using the PTO powered backhoe instead of the tractor hydraulics, but if you keep your quick couplers clean, i.e., wipe them off good if necessary before hooking them up, there's no reason for that to be a concern. Real farmers change hydraulic powered implements all the time without worrying about that.
Bird
   / Backhoe #6
Bird,
I'm really not all that worried about contaminating either the tractor or the backhoe hydraulic fluid...I'm pretty meticulous when it comes to keeping things clean (although my wife might feel that the word "meticulous" isn't strong enough /w3tcompact/icons/smile.gif).
When I was researching backhoes the general concensus was to use a PTO pump (for a variety of reasons)...cleanliness was the reason that came to mind quickly this morning when I responded (gee, maybe my wife is right... /w3tcompact/icons/smile.gif). The other posts here that mentioned the hydraulic requirements (flow and pressure) were the other major reasons cited in the posts I researched. The whole idea of a sealed, self-contained unit seemed better to me.
I know that the PTO pump route has worked well for me...and I'll second the posts above that mention using a sub-frame. I specifically got a Woods hoe because there was no sub-frame available for the Kubota hoe. Not that I'm all that tough on the equipment, but why not have the strongest arrangement possible? Right?
Bill
   / Backhoe #7
Re: Backhoe..JiminMI&JimBinMI
After reading the post I look at the name below and just about fell out of my chair. /w3tcompact/icons/shocked.gif
I stared and stared at the name,WHAT..Jim finally had enough of his NH and now wants to buy a L3010 FEL & backhoe?? /w3tcompact/icons/crazy.gif/w3tcompact/icons/shocked.gif/w3tcompact/icons/smile.gif
I had many thoughts of will wonder never cease or maybe I should go out and buy a lottey ticket..what a day. /w3tcompact/icons/smile.gif
Than I notice no "B". /w3tcompact/icons/frown.gif
Ahhh maybe someday it could happen,have my fingers cross for you Jim.
JiminMI&JimBinMI I guess I need to look more carefully or make my coffee stronger! /w3tcompact/icons/laugh.gif/w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
   / Backhoe #8
Bill, I agree that the PTO powered hoe has some advantages, primarily if it's on a tractor without an adequate hydraulic flow capacity, like TomG mentioned. But I'd consider the possibility of hydraulic fluid contamination to be the least of the concerns.
Bird
   / Backhoe #9
Well the pump supplied by Woods is only 6gpm. The pump by Kubota is probably the same. We have been using the tractor hydraulics quite a bit when selling these outfits and have had good luck with both the tractor and the backhoe. I used to look at keeping the oils seperate but it doesn't seem to be a problem. Now about the neighbor who likes to borrow your tools?
   / Backhoe #10
JimInMi - You didn't say what backhoe you're getting but, in general, running it from the tractor's hydraulics shouldn't be any problem if they're anywhere near properly matched, as has been said. For example, I run a Bradco 609 (2,000 lbs) on my L4310HST regularly and it works great, despite the fact that the Bradco's specs call for 10-12 GPM, and the L4310 only has 8 GPM or so. Again, as has been said, keep the connectors clean and it's not a problem, but a lot less hassle.
As for a much cleaner approach to doing it than I've ever seen anybody else do, a hydraulics engineer helped me plumb the connections in such a way that even satisfied me. I posted a message on the old forum almost exactly a year ago (11/19/99) which has some details on it you might want to consider. Since there's no links to the old forum anymore (at least not that I can find), I'm reposting the old messages on my current "L4310 Enhancements" thread in the "Kubota Owning" discussion area in a few minutes, in case you want to see them.
MarkC
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
