Backhoe when not in use?
   / Backhoe when not in use? #1
Indian MC
Southeast, NH
Kubota B2601
When not using my machine, I was told to set the FEL down on the ground to avoid it coming down on its own from sitting.
How about the backhoe? I have been using the two pins that lock the boom but not the bucket in place.
I noticed today my bucket is leaking down from sitting. ( About 6" in five days ).
Is there a need to set the bucket to the ground when you don't intend to use it for several days?
   / Backhoe when not in use? #2
I prefer to set it to the ground. It minimizes flat spotting the tires, but as long as the boom is pinned up there's no other reason to do so.
Thanks, I'm a little cramped for space. Behind the hoe I only have two feet to the garage door.
Up front, I have more stuff than I care to move around right now.
I lifted the bucket back up, and slid a Jack Stand under.
That will do her!
   / Backhoe when not in use? #4
It's normal for backhoe cylinders to leak down slowly on their own. As for parking the backhoe, I always treat it just like any other implement: when it's parked and not in use, it is fully lowered to the ground so it can not move. I don't want my grandkids, kids or me to have an "oops" moment by accidentally or playfully bumping a loader or backhoe control.
   / Backhoe when not in use? #5
Since ours resides outside, we use the pin to lock the boom. For the BH bucket we lower the front of it so that water will not fill it up when it rains (I won't say "if" in Florida)
For the FEL, we drop that to the ground. Not only does it keep it from dropping, it is like setting the "parking brake" for the tractor. If we think we are going to be parked for any amount of time we will lower the bucket after we tilt it down and lower it with the bucket facing the ground.
   / Backhoe when not in use? #6
I lower the front bucket and make sure it is fully one the ground. This means I move the loader control until it does not move. Like Grandad, I would have for one of the kids to play on the tractor and trap or pinch someone. It would be a real disaster as they would have to start the tractor to lift it off them. The backhoe gets left against the pins. The tractor has to be started to get the pressure off the pins.
   / Backhoe when not in use? #7
I have space issues as well. I swing the boom all the way to one side and use the locking pins for the boom and outriggers. Then I relieve the pressure on the hydraulics and let the bucket droop to where gravity takes it. The FEL is on the ground. Again, I relieve all hydraulics so nothing is going to move should the kids find something interesting in there...
   / Backhoe when not in use? #8
The issue is not to set the bucket on the ground at all. It doesn't matter a bit where you put it. You can sit it on a milk crate if it doesn't collapse.
The issue is relieving the hydraulic pressure.
For your backhoe, having it against the pins is fine. For the bucket, once the engine is shut off, just move the bucket handle until, it reaches bottom all by itself and relieves the pressure in the hydraulic system. Same for boom in and oput on both arms. What you are trying to do is remove the hydraulic pressure from the seals.
Same with the front bucket, just let it down once the engine stops and operate all the controls so the pressure is gone and you're fine.
You do exactly the same with a forklift ... let the forks down and lean the mast forward or back until it stops all by itself. The pressure is zero and you're good to go.
   / Backhoe when not in use? #9
You can wrap a ratchet strap around the bucket to keep the curl cylinder from sagging. I strap the bucket or rather ripper tooth and the stabilizers on mine. The boom I pin.
   / Backhoe when not in use? #10
There is no valid reason concerning the hydraulics to lower an implement, IMHO. Considering the 2000 PSI the hydraulics are designed to handle, the resultant pressure created by the weight of the implements is insignificant. That being said, I do personally drop both my backhoe and my bucket onto the ground to transfer the weight of both off of the tractor tires.
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
Ford F-550 Bucket Truck (A51692)
Ford F-550 Bucket...
