Backhoe backhoe subframe issue
   / backhoe subframe issue #1
orangekubotadriver
I own a 3130 and need a backhoe. The local dealer first mentioned the bh75 size backhoe because he initially thought the bh95 was too big - but then, after looking at the kubota specs, he found that the only subframe for the 3130 was for the bh95. Also, including the loader that I have to buy, it's going to cost around $15k (including tax) turn key. My question is whether the bh95 is pushing the 3130's limits to the extreme and if the price seems a little stiff.
thnx all.
   / backhoe subframe issue #2
For 15K I think I'd look into a separate used machine that already has the equipment you need....
   / backhoe subframe issue #3
A loader is typically about $6k and a BH is about $9K so the price is in line. A used machine with both might be hard to find for $15K.
Andy
   / backhoe subframe issue #4
Used prices are so good now that I would not consider buying the backhoe for your 3130.
As background am using a B21 to prepare a 4 acre previously wooded home site with lots of rocks and 640' of electrical trenching.
My preferred options would probably be to buy a FEL for the 3130 and a used mini excavator. I bet you can get a used mini x for around the price of the backhoe attachment. The mini x will be easier to use and more capable.
Alternately I would buy a used more industrial TLB, a B20, B21 or L35. You certainly could get a good condition B20 or B21 with FEL and Backhoe for less than $15K. You might be able to find a L35 in the budget.
   / backhoe subframe issue #5
If you decide to look at Woods hoes, I have an unused 1006863 subframe that fits a 3130 and several Woods hoes. Will sell quite cheap.
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 KENWORTH T880 MID-ROOF SLEEPER (A52472)
2015 KENWORTH T880...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
MILLER SYNCROWAVE 351 TIG WELDER (A52472)
MILLER SYNCROWAVE...
