Mowing Backhoe subframe and midmount mower
   / Backhoe subframe and midmount mower #1
Tryno
Missouri 40 miles north of Springfield
TC 30 (Sold D17 and miss it)
Ok still waiting on the new TC30, received a call from the dealer today. They are having trouble setting it up with a subframe for the backhoe and still be able to mount a belly mower. Anyone run into this problem? What is the solution? Backhoe is a Bushhog 750, belly mower is 60". Dealer is checking on different backhoe brands. Another solution we discussed was for me to take the subframe off when I need the belly mower. How much extra trouble will that be? I offered to go up to a TC33 if it would solve the problem. If I have to move to the 33 or take the subframe off everytime, I think there should be a price adjustment somewhere, what do you think? Thanks Terry
   / Backhoe subframe and midmount mower #2
I think he should have done his homework before he made the deal. I know of no subframe/MMM combo that is compatible on an NH compact. Maybe someone will prove me wrong; I haven't done any setup for a couple years; just repairs.
Thanks Rick, how much trouble would average person having putting subframe on and off? How long would it take? Any idea? Suggestions?
   / Backhoe subframe and midmount mower #4
I can't speak directly to a BH backhoe because while we sell the brand, we don't sell their hoes. It would be safe to assume the backhoe subframe occupies the same space as the MMM front brackets. Others will disagree, but I believe with NH at least, if you opt for a MMM and have to use it weekly, you basically have a dedicated lawn mower. Removing bracketry, much less a complete subframe with any frequency is more than I would want to sign on for. Dropping the deck alone is bad enough. Rear finish mower technology has come a long way, maybe you could look at a high quality rear discharge RFM. I don't see any relief from 'looking at' a TC33; the tractor chassis is substantiallly the same as a 30.
   / Backhoe subframe and midmount mower #5
I had a 60" mmm and as far as I know, the bh subframe uses the same bolt holes. At a minimum, the mmm brackets will be in the way. When I sold the mmm, I had to remove all the mounting stuff and it's not something I'd want to be doing on a regular basis. IMO, a backhoe and a mmm are not a viable combination.
   / Backhoe subframe and midmount mower #7
<font color="blue"> I had to remove all the mounting stuff and it's not something I'd want to be doing on a regular basis. IMO, a backhoe and a mmm are not a viable combination.
</font>
I agree with Mike, it's not something that you would want to change back and forth on a regular basis. I have a Class III with a NH backhoe and I wouldn't want to remove all the hardware more than once myself.
   / Backhoe subframe and midmount mower #8
I'd bet the time to setup/breakdown the MMM/backhoe brackets would be measured in hours not minutes.
If you are only using the hoe 2-3 times a year, don't spend your money - rent a compact excavator for $300.
If you are only using the MMM 2-3 times a year - I'm assuming this is "field" or "pasture" mowing. The MMM is the wrong tool for that job - get a rotary cutter - aka "bush hog". Cheaper & designed to mow tall grass.
If you want a finish mower (for cutting lawn) and a backhoe on a New Holland product - you will need to get a rear finish mower. I had a landpride RFM (loaned to me while I waited a few weeks for the MMM to come in). It had a better cut than the MMM. It was a bit tougher to manuver around all my trees, but manageable. It was also $800 cheaper than the MMM.
Good luck.
   / Backhoe subframe and midmount mower #9
<font color="blue"> what if you were only making the change 2 or 3 times per year? </font>
That's a tough call. What's merely inconvenient to one person can be a major pain to someone else. Plus, it's not just removing the mounting hardware, it's setting up and adjusting the springs that attach to the rear axle. Ask the dealer for copies of the bh and mmm installation manuals to see what's involved. I'd opt for a rmm.
rmm doesn't work for my needs. Will have a brush cutter for rough pasture. mmm will be used along with a trac vac to pick up leaves/grass clippings. Renting a backhoe was considered but doesn't work well with my schedule. Looks like I will learn to do the subframe mounting. Thanks Terry
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2021 Western Star 4700SF Tri Axle Dump (A47384)
2021 Western Star...
T3 Motion Patroller Segway (A51694)
T3 Motion...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
UNUSED MOWERKING SSECAG-Y AUGER BITS (A51244)
UNUSED MOWERKING...
(2) SODA FLO CONTAINERS (A51244)
(2) SODA FLO...
