Backhoe Stabilizer Pads?
   / Backhoe Stabilizer Pads? #1
Jackrabbit_Slim
B.C. Canada
B2710
Didn't realize the rubber pads on a Kubota backhoe stabilizer pad were not included in the purchase price.
Thinking about getting some rubber stall mat (recycled tires, I believe) and using that.
Anyone ever done this? Advice on laminating two pieces together for extra thickness?
Thanks,
Slim
   / Backhoe Stabilizer Pads? #2
I just use a couple of scraps of 2x6 held on with lag screws when I need a pad. They have lasted quite a while now. I only use them when I'm on our asphalt.
Greg
   / Backhoe Stabilizer Pads? #3
Never had any need for the rubber pads. Most of my digging is in the dirt so I reverse the stabilizer pads on my New Holland backhoe and they dig in and get a better bite.
Do you use the rubber if you are on concrete or blacktop?
   / Backhoe Stabilizer Pads? #4
<font color="blue"> "Do you use the rubber if you are on concrete or blacktop? " </font>
That's the idea. I believe the JD versions are even called concrete pads. I know there is a reference in the manual to using them on concrete to avoid damaging it. On dirt there's really no reason to use them or not. /forums/images/graemlins/smile.gif
   / Backhoe Stabilizer Pads? #5
I have found that asplat and concrete are very slick when trying to hold the tractor still while useing a BH. I dont have pads either but need some. it can put heavy scars in the surface of asphalt.
   / Backhoe Stabilizer Pads? #6
</font><font color="blue" class="small">( I just use a couple of scraps of 2x6 held on with lag screws when I need a pad. Greg )</font>
This is what I do as well. I drilled some holes and hold them on with bungees. The Deere feet have a pointed flange on each edge of the feet, so once the 2X6's are set down on the concrete, they aren't going anywhere. Seems to work quite well.
Cliff
   / Backhoe Stabilizer Pads? #7
Slim,
On our larger Case, we took the rubber pads off, which were essentially a number of rubber strips about 4" wide sandwiched together and stood on edge between two pieces of angle, which were the length of the existing plate.
The angles each have 2 holes which allow you to bolt through your existing stabilizer plates. They can be easy on/off.
Make sure the angle is not quite as high as the rubber, else you'll tear up the surface you are trying to protect.
I don't know what the stabilizer plates look like on your Kubota, but if they are flat, should be pretty simple to use existing holes or make new ones.
Good luck.
-JC
Thanks, JC. Reading your description really helped put the plan together. I think I should be able to assemble a pair and get exactly what I want. Appreciate it.
Slim
   / Backhoe Stabilizer Pads? #9
Slim,
No problem, glad to help. I've gotten some pretty good advice from the good people here, so I try to return the favor.
I should also mention that there were two bolts running between the angles, through a hole in each of the strips to hold them secure. Not sure if they would be needed on a smaller machine, but would hate to see them slip out /forums/images/graemlins/frown.gif
Good luck
-JC
   / Backhoe Stabilizer Pads? #10
Sorry I'm posting so late. Just to illustrate another way to go.
I built a scrap steel piece that pins to the stabilizer foot and glued a piece of hiway retread that had fallen off some 18 wheeler.
This is a close-up of one of the pads mounted.
Here we are ready to dig. A short thread was posted on their construction.
OkieG
Kubota F3990 72in Front Mower (A50322)
Kubota F3990 72in...
UNUSED MOWER KING SSFFGC175 HD FLAIL MOWER (A51244)
UNUSED MOWER KING...
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
(INOP) KUBOTA L2550 TRACTOR (A51243)
(INOP) KUBOTA...
3 PT DIRT SCOOP (A51243)
3 PT DIRT SCOOP...
New in Crate 20' x 40' Hoop Building (A50515)
New in Crate 20' x...
