Backhoe slowly falls down over night>?
/ Backhoe slowly falls down over night>? #1
jokergerm
So i parked my L3800 with BH77 last night with the boom all the way up and curled in and when i got up this morning it was on the ground. Is this normal? the dealer said that its normal for it to fall a certain amount per hour? i think this is crap how can a new machine do this?
/ Backhoe slowly falls down over night>? #2
I have a Woods BH and it would do the same thing over a couple day's (they said it's normal). A couple months ago it started doing it in a few minutes. If I had it all the way up and moved from one side to the other it would fall all the way down. I took it in and they found the pistons were scored by debris inbetween the internal seals. Keep an eye on how fast it falls and if it starts falling faster than you might have a similial issue.
/ Backhoe slowly falls down over night>? #3
Good grief man, your going to die a young age from all the tractor stress you induce on yourself lol. Its totally normal. L48's did it, alot of smaller hoes do. The check valving to hold up that weight is expensive. The mini exes with pilot contols will hold position. You should have a storage latch or pin to hold it up. Use it.
your telling me, i have had more stupid issues with this kubota. Half of them i have not even posted about.
I bet the dealer has picked up my tractor and taken it back to there shop 10 times since i bought this thing 2 months ago.
4 times for a leaky hydraulic fitting (that still Leaks)
its been obsurd.
/ Backhoe slowly falls down over night>? #5
Joker
I feel ya with the hydro line leaks my B3300su had a few leaks on FEL and BH when I got it but I repaired them myself with a little Teflon tape, I know many say not to use it but I used it sparingly and made sure it was on correctly. Also on the backhoe sag LOL yea if I don't lock my BH77 in the up position it will fall overnight it happens. Enjoy the tractor bud.:laughing:
/ Backhoe slowly falls down over night>? #6
Without the retention pin installed, it will leak down.
/ Backhoe slowly falls down over night>? #7
My boom will bleed down too if I don't latch the uplock on my Bradco/Mahindra 511. The bucket droops also.
hugs, Brandi
/ Backhoe slowly falls down over night>? #8
My Massey implements will drop down overnight also, It's absolutely normal.
/ Backhoe slowly falls down over night>? #9
All hydraulics have an allowable leak down.
For example our fork lifts at work are allowed 1" per hour for the mast per the oem is normal and 2 1/2" per hr is were they suggest rebuilding the cylinder or valve.
tom
/ Backhoe slowly falls down over night>? #10
I'll throw my 2 cents at this - Whenever a tractor is shut off everything should be lowered to the ground so if the valve levers move nothing else does. On a backhoe, the transport lock can be used - but resting it on earth is safe and easy.
On the leak-down issue, they all do it - some more than others. Pilot-operated check valves help, but piston seals can still allow some creep.
/ Backhoe slowly falls down over night>? #11
If it doesn't leak, it isn't hydraulic... PERIOD
/ Backhoe slowly falls down over night>? #12
It is not only the cyl that leak down, but the valve also. It all amounts what you can accept, and there is a drops per minute leak rate, to determine the good/OK verses bad /replace.
Most people do not know to ask about the leak down rate. They could raise five new loaders in the air, and maybe one will still be up the next day.
It would be a good idea to release all the hyd so all booms, etc are on the ground for safety.
/ Backhoe slowly falls down over night>? #14
:confused: Hmmmmm not sure why anyone would leave a bucket in the air with no one around, SAFETY !
/ Backhoe slowly falls down over night>? #15
I was just going to jump in and say "I thought we were supposed to ALWAYS leave them DOWN when not in use?"
Thanks for the clarification!
/ Backhoe slowly falls down over night>? #17
internal or external...
/ Backhoe slowly falls down over night>? #18
Please read and remember J_J's advice...
ALWAYS lower implements to the ground...you just never know...kids could come around and push a lever...while one of them was under the suspended implement.
Yes it might never happen but could...err on the side of safety...
/ Backhoe slowly falls down over night>? #19
Another reason is holding pressure in the system is wear and tear on the hoses, valving, seals and pivots. Still mainly for safety though ... Loader forks or bucket on the ground, nothing to walk into at head level. Would you leave a rake laying on the ground tines up ??
/ Backhoe slowly falls down over night>? #20
Some people do. That's how I ended up with 4 holes in my foot when I was kid.:thumbdown::shocked:
2022 EZ-GO ELITE...
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
Massey Ferguson 250 Tractor (A62613)
Massey Ferguson...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
