Backhoe Size?
   / Backhoe Size? #1
straightsix240
Hey everybody, I'm new here. I've got a Kubota L3750 4wheel drive tractor with a front end loader on it. I've got the opportunity to buy a Bush Hog brand backhoe, model 860 H. Would this backhoe go on this tractor? It is a 3 pt hitch mount, but it's on a Ford 4610 right now and I wasn't sure if it wasn't a little big for my Kubota. The backhoe has a 16" bucket on it right now.
Thanks!
David Hammond
   / Backhoe Size? #2
My Bush Hog brochure lists the BH850, and the current 8.5-ft hoe is called
the 85CBH. I don't know of any "860" hoe from BH.
If it is like the BH850, I would be inclined to think you can mount it safely to your
L3750 with a good subframe. It calls for 6-8 GPM/2400psi hydraulics.
   / Backhoe Size? #4
:welcome: to TBN! That hoe requires 5-7 gpm, 2,200 psi, weight less bucket 1,095 lbs direct from manual found on ebay right now.
I would probably get a frame mount from the dealer for it. Thats a lot of weight on the hitch, especially when digging.
   / Backhoe Size?
Thanks guys! The Bush Hog 860 H is a three point hitch mount, and it has it's own hydraulic pump (PTO powered). I don't know exactly what year the backhoe is from, but it's on a Ford 4610 tractor right now, that is probably an '88 to '90 model, so the backhoe would be similar age. I don't know what the lady is asking yet, so that's the biggest unknown.
But if I have to have a sub-frame mount then this won't be practical for the Kubota as I need the 3 pt for several other implements... Any other ideas?
Thanks again.
David Hammond
   / Backhoe Size?
The lady also has a Goossen Chipper/Shredder, PTO powered. Anyone ever use one of these; how powerful are they, how do they hold up, etc.?
David
   / Backhoe Size? #7
...... if I have to have a sub-frame mount then this won't be practical for the Kubota as I need the 3 pt for several other implements...
David - The subframes made for Kubota tractors like the L3750, for mounting Kubota or Bradco backhoes, do not interfere with 3-point hitch implements. Even if you don't find one of those sub-frames (getting rare these days) the L3750 has a strong enough chassis to handle a 3-point backhoe if operated within reason. The L3750 is one of the older Kubotas with big bones - very rugged. It has a 2-speed pto as well which will do a nice job with the hydraulic pump on this bh.
   / Backhoe Size? #8
I have been thinking of a small backhoe for my BX2230.Does anyone know of a hoe that would fit or will I have to get a bigger tractor? It would sure beat a bar and shovel:laughing:
   / Backhoe Size?
Thanks rbargeron. So the subframe is just something bolted onto the tractor frame that you hook the backhoe to when you put it on the 3 pt hitch? Sorry for being dense, I'm new to these 3 pt backhoes.
The L3750 does indeed seem to be a rugged old beast. The hydraulic pump went out a few months ago, but with a new pump the old girl can pick up 2400 lbs on the front end loader with pallet forks!!
Where's a good place to hunt for a sub frame?
David
   / Backhoe Size? #10
Check with the manufacturer of the bh, or if you're up for a welding project there's several threads on making subframes for backhoes. Other sources might be eBay.
2021 John Deere 9420R Tractor (A53342)
2021 John Deere...
JOHN DEERE 2038R LOT IDENTIFIER 162 (A53084)
JOHN DEERE 2038R...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
