Backhoe Backhoe Quick Disconnects Repressurizing??
   / Backhoe Quick Disconnects Repressurizing?? #1
knute_m
Moved from Hilltop Hollow, WV to Outskirts of Winc
Down to my lovable little red Mahindra with FEL, and backhoe.
Several months ago, I bought a 2710 backhoe for my little 2015. Fantastic machine for pond maintenance and stump removal!
But, I've removed the backhoe twice, and I've put it back on twice. Both times, the hoses on the backhoe seem to have repressurized while the backhoe was stored. I now believe it is probably happening because I don't have a slab or garage where I can store it. It is stored on a gravel pad, over clay, where it slowly sinks.
Both times, I've had to use a wheel puller to release the pressure in the lines. I tried putting a rag over the longer QD line, and pushing the coupling with all my weight into a board, but nothing happened. I didn't want to whack it with a hammer -- so, thus, the wheel puller with a metal washer, rubber washer, and lots of rag wrapped around the coupling. Once it drains a little bit of oil, I can install the lines without any problem.
Anybody else had this problem? Any solutions?
Thanks,
Knute
   / Backhoe Quick Disconnects Repressurizing?? #2
Take a couple of wrenches and loosen the quick disconnects and let the pressure bleed off. I know that it is a pain, but it works.
   / Backhoe Quick Disconnects Repressurizing?? #3
Put a stand under the center of the backhoe for it to set on. Make the stand a couple of inches shorter than the height of the backhoe when installed. After the backhoe is setting on the stand there shouldn't be much pressure on the hoses. If you have anymore questions about it give me a call or ask me here on TBN. Good luck with it!
Thanks Brian and Galen.
-- Brian -- As you suggest, loosening the couplings was my first thought. As I walked down to the barn for tools (about a quarter mile), I had second thoughts. The reason I ended up using the wheel puller was so that I wouldn't have to loosen any of the threaded couplings. I figured that by depressing the check valve button on the QD a very small amount, with rubber gasket material between the button and the wheel puller, I'd do little damage to the coupling. It also allowed me to put a pretty good buffer (over an inch of rags) between the high pressure hydraulic fluid and my skin. I've got kind of a hangup about loosening pressurized hydraulic couplings, but I've got a real concern that they lose more than just a little integrity each time they are tightened.
-- Galen -- your answer was kind of like the V-8 juice commercials. Why didn't I think of that? I guess that is what is so great about this forum. I've got a bunch of pressure treated lumber, and some 24-inch square concrete paver blocks, behind the barn. Some of this will become a backhoe stand over the weekend. I think that if I can keep the backhoe from moving more than a few fractions of an inch after I remove it, it will not repressurize.
Again, thank you both for your responses.
Knute
   / Backhoe Quick Disconnects Repressurizing?? #5
Thanks,
Knute
Yes, I have the answer to your problem, simply install a high pressure tee and high pressure steel shut off valve on the backhoe QD. I believe you only need one setup. Once installed, all you have to do when connecting the QD's, is to open the valve and release the pressure, then you should be able to connect. You can also use the valve to install a pressure gage to check pressure.
   / Backhoe Quick Disconnects Repressurizing?? #6
Knute
Just about any system with QD's, can build up pressure just by an increase in temperature change. Also, if those QD's are left in the rain, and you have a temperature drop, they can/will suck in some water or air.
   / Backhoe Quick Disconnects Repressurizing?? #7
If the valves are on hoe while its proped up move the levers to balance pressure in lines.
tom
   / Backhoe Quick Disconnects Repressurizing?? #8
Thanks,
Knute
Knute,
Once you have demounted the BH, and the tractor is a few feet away from the BH, put some blocks under it. I use 3. One under each stabilizer pivot pin and one under the boom pivot pin. Then I settle the BH down on the blocks. Turn the tractor off, move all BH controls, then move the remote lever to netral. I then wiggle all BH controls one more time before disconnecting the hoses. No pressure anywhere. :) Oh yeah, I have the fixed thumb deployed to aid in stabilization.
hugs, Brandi
   / Backhoe Quick Disconnects Repressurizing?? #9
If any of my attachments are off for any length of time there is pressure on the hoses . I just grab the hose with the male disconnect and hit it square on a flat part of the BK or FEL. A little fuid will be released and it will couple right up.....
Dave in NH
   / Backhoe Quick Disconnects Repressurizing?? #10
maybe you could just make a small hydraulic coupler that was a male on one side and a female on the other and connect the two hydraulic connectors together when you put it in storage? Then rest it on wood or concrete blocks as described and the pressure would balance.
Year: 2013 Make: Ford Model: Flex Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 175,101 Plate: (A50324)
Year: 2013 Make...
2019 KUBOTA SVL75-2 SKID STEER (A51242)
2019 KUBOTA...
UNUSED FUTURE GALVANIZED STEEL SITE FENCE (A51244)
UNUSED FUTURE...
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
1998 JOHN DEERE 310E BACKHOE (A51242)
1998 JOHN DEERE...
2017 CATERPILLAR 320FL EXCAVATOR (A51242)
2017 CATERPILLAR...
