Backhoe Backhoe question and advice
   / Backhoe question and advice #1
Lynn_O
Ok, planning on buying a DX33 or equivalant. What size and
brand BH do you think i show get. And what and average
price for such a BH, with a subframe mount. Also another
dum question. If i go with a subframe mount backhoe can i
detach the backhoe to run a finishing mower, and if so how
hard is it to do.
   / Backhoe question and advice #2
Don't know about the DX33 or what brand of BH to suggest for this tractor, but I would suggest a subframe mount for the backhoe.
Most all subframe mounts are rather simple to attach and you should have no trouble switching from the backhoe to any other implement. /forums/images/graemlins/grin.gif and WELCOME TO THE BEST TRACTOR FORUM ON THE INTERNET. /forums/images/graemlins/grin.gif
   / Backhoe question and advice #3
could someone post a picture of the backhoe subframe without the hoe on. I also am concerned about using 3pt with the subframe, but have not seen one.
   / Backhoe question and advice #4
Not sure about the DX but on my New Holland the front subframe brackets bolt right where the belly mower brackets go. You can still use a 3ph mower easily enough.
I went with the Bush Hog backhoe. Subframe mounted with rear remote was $6100 or $6500 installed. I put it on myself and saved $400. It was easy to install. I went with the Bush Hog 750. It's a nice sized hoe and would work well with your tractor or you may want to move up to the 850.
buckeyefarmer:
I don't have any pictures of just the subframe. On mine when removing the hoe, the subframe stays with the hoe leaving just 4 small brackets attached to the tractor. There's nothing left to interfere with the 3ph.
PICS
Thanks for the welcome aboard
Hey, thanks that really helps out. Pictures really look good.
Could not tell from the pictures, what size tractor and HP.
Also i am going to probably get turf tires, since i had my 5 acres leveled and dont want to make any more ruts. Do you
think i need to have my rear tires filled or something, if i get
a BH, and if so, what is there on the market to fill with.
   / Backhoe question and advice #7
Welcome to TBN from a native buckeye! One of the great features of TBN is the search engine... you can find something on almost any tractor topic.
In May, 2004, one of the regulars here, txdon, posted a series of pictures of how the Kubota BH90 backhoe goes off/on his L5030. That should give you a very clear sense of what is involved. My computer skill isn't up to actually adding the link to those pics in this message, but if you use the search feature in the Kubota Owning/Operating section, and search for BH90, it will turn up.
The changeover from BH to 3pt. is easy. The toplink just pops off, and you have a couple of pins to pull for each of the lower links. 2 minutes, even for a slow poke like me. Another couple minutes to get the BH and tractor lined up, and you're done. It's really only a 10-15 minute job, once you've done it a few times.
   / Backhoe question and advice #8
When you want to add a link to another page or site, copy the URL/Address by highlighting the address bar and right click, choose copy. Then when you post, type your message, click on URL in Instant Markup below where you type your message. Right click in that pop up window and choose paste to put the address in there and click ok then type in a name for your link in that pop up, click ok and your link is now in your post.
When searching, make sure you choose a time frame from the drop down windows. The default selection is only newer than 1 week, so you may need to increase the time up to newer than one year or choose All Posts.
John
   / Backhoe question and advice #10
Lynn,
The tractor is the TC30, rated at 30hp. I have loaded R-4's on mine. You may want to check to see if turfs are ok to use with a backhoe. I don't know but I think turfs usually have less plies and may not be rated for the load. Some one else here may know for sure.
It's not necessary but it helps to have loaded tires. My dealer fills them with anti-freeze. Some people use windshield washer fluid. Also used is calcium chloride and a newer product called beet juice. The pros and cons of each are discussed in several threads on this board.
Good luck with the tractor purchase!
Rodger
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2007 Pace American JT716TA2 20ft T/A Enclosed Trailer (A49461)
2007 Pace American...
Bus (A50323)
Bus (A50323)
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
