Backhoe Backhoe Pin Wear
   / Backhoe Pin Wear #1
BXTotal
Kioti CK20
I recently bought a CK20 with the factory backhoe. The tractor has about 500 hours on it, so I assume the backhoe has less than 500 hours.
Before I bought the tractor, I examined many of the pins for the FEL and backhoe. They all had very little play and appeared to be well greased. The previous owner warned me that there might be one or two fitting that were plugged.
The first time I used the backhoe I noticed that the pins that allow the backhoe boom to pivot from side to side had a bunch of play. The lower pivot point is not too bad but the upper pivot is totally out of whack, like half an inch or more. This seemed odd to me because the other pins were in good shape and the tractor only has 500 hours.
This weekend, I extracted the lower pin and it was totally dry- no grease. More surprising, there was no sign of any radial grease hole running from the bearing surface of the pin to the center grease hole. The center hole was full of fresh looking grease.
The upper pin would not budge. It looks like it welded itself to the flange. The pin itself is distorted so, even if I could rotate the pin in the flange (which I can not) I doubt I would be able to extract it.
Two questions:
1. Is it possible there there was a manufacturing defect and my pins were never drilled with holes to carry grease from the fitting to the bearing surface ? Has anyone ever heard of this before ?
2. How in the world am I going to remove the old upper pin that has welded itself to the flange ?
   / Backhoe Pin Wear #2
I see this is your first post so welcome. :thumbsup: :) I have a woods backhoe on my CK35 and I grease all my pins a fair amount. Sounds like the previous owner of your machine didn't grease everything. I keep a few grease zerks so that if they plug up I just change them; it does happen from time to time. My first thought would be to get a manual for the backhoe and/or talk to a dealer about the problem. This would help you find out the location of all grease points. As far as getting out the pin I am sure it can be done. If you have a heavy equipment shop near you they may be able to help you as well. Lots of different types of equipment have pins and I'm sure they occasionally have to take out seized pins.
   / Backhoe Pin Wear #3
I'm not sure what you mean by a "radial grease hole". On the pins in question on my tractor the grease is distributed by squeezing around the pin after exiting the middle pin grease hole. It is odd that you see fresh grease in that hole but totally dry pin with excessive wear. Maybe I am not understanding. Does the pin have a zerk but no exit point for grease at all?
It is also odd that the pivot pins would weld themselves as there really is not enough repetitive friction in pivoting to get the pins hot enough to weld IMO. cycling back and forth between digging and dumping spoils could certainly wear a pin down if it was not greased but I'm having trouble imagining enough heat generation to get metal to a welding point.
   / Backhoe Pin Wear
IslandTractor & Mousefield, thanks for the thoughts on this problem.
IslandTractor, this is exactly what I am suggesting. The zerk is intact but there does not appear to be any passage drilled to carry the grease from the zerk to the actual working surface of the pin. Either there was never a passage or the passage has somehow welded shut. Right now there is definitely no sign of a hole to carry the grease out from the zerk.
As for welding the pin to the flange, I am using the term weld loosely. Really it looks more like the pin rusted, galled, and mushroomed enough that it is locked to the flange. I was not able to budge it with some casual hammering or a pipe wrench (twist).
   / Backhoe Pin Wear #5
We love jobs like this!!!
Its going to take heat, and a big hammer.
I bought a big slide hammer off the Mac Tool truck just for these occasions.
You can remove the grease fitting and apply heat to it and you may get lucky enough that the old hard as a rock grease will start to run out.
You can also apply heat and try a impact hammer.
Sorry I don't have the magic answer.
   / Backhoe Pin Wear #6
The brass bushings(are whatever material is used) should have the grease gaps for grease to travel around the pin, 500 hundred hours run time and equipment setting in the feild with little to no maintenance could be the culpret, I just torched out a set of swing bushings on a 555E back hoe that belongs to a graveyard, A couple six foot holes a week or more but no one @ the company including operators had a clue were the zerks are and had never tryed to locate them, put some heat and sweat into a big hammer!! The damage is already done and you have committed to it now!! I also have cut grooves in pins to let grease travel through!!
   / Backhoe Pin Wear
Thanks for the replies.
Not sure I was sufficiently explicit about the situation with the grease fitting. For both the lower and upper pin, the zerk is on the pin. It is centered on the top side of the pin.
When I pulled the lower pin (the one that is not seized), there was no sign of a hole to allow the grease to travel from the zerk to the exterior of the pin where it is needed. What the previous owner though was a plugged zerk looks like a manufacturing defect to me. You could apply as much grease with as much pressure as you want to that zerk fitting but none of it is ever going to reach the bearing surface of the pin because there is no passageway.
Regarding the upper (seized) pin. I have a bad track record with a hammer and blow torch. Can I really bang on that thing hard enough to get it out without breaking the flange ? The last time I had this problem, it was a seized trunion on an old car. Broke a bunch of wrenches, almost flipped the car with a 12 ft breaker bar, nearly set the garage on fire with the torch. Never did get the pivot out of the trunion.
   / Backhoe Pin Wear #8
I'm an optomist. Try some PBblaster daily for a week or so along with a healthy whack with a mallet and use the BH hydraulics to move it back and forth. Then mild heat and see what happens. You might get lucky. If that doesn't work send it out to the gorillas.
Rick knows what these pins are supposed to do regarding grease so maybe he can answer your question about the missing grease passage. I'm having trouble envisioning the grease path. I would add though that you don't need to cut any grooves in the pin, so long as the grease exits the middle of the pin somewhere the grease will easily distribute itself with movement of the BH.
   / Backhoe Pin Wear #9
I'd try using an industrial strength bolt loosener- (fluid) in conjunction with a heat gun AND an impact driver (air chisel) to free the pin. First apply the bolt loosener and then the heat followed by an air chisel set to medium impact to start and higher air as needed. Apply the heat to where the pin is held into the flange, NOT to the pin itself. Your task is to expand the opening and drive the pin through the expanded opening. Hit the center of the pin with the impact hammer and try to keep from mushrooming the edges any further than already is the case.
The less pressure on the pin from the BH the better too. Do what you can to relieve as much pressure on the pin by positioning the backhoe in a place where the pin is as free as it can be.
One other thought is to try to drill out the existing pin- especially if all else fails. There has to be a type of bit- possibly the newer cobalt bits that could at least core out the pin enough to be able to punch it the rest of the way.
Try Grainger Supply or some other industrial supply co. to see what exists for such purposes.
good luck and wear appropriate eye hand protection :thumbsup:
   / Backhoe Pin Wear #10
As Wallace and Island mentioned, heat and PBblaster or any other good penetrating oil should work to loosen it up. Working on cars and an old D5 Cat bulldozer, I would oil the part good and let it soak 30 minutes or so. Apply the heat to the flange as Coyoti mentioned, I used an acetelyne torch. It will boil the oil and loosen it a little. One trick I've used is while it's hot, hit it again with the oil. The oil starts to cool the parts and is sucked in further. Try to pound it out or better an impact gun as mentioned. I've had to do this several times to stubborn parts but they finally let lose.
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2013 VOLVO VNM...
John Deere 4044M (A50120)
John Deere 4044M...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2016 Peterbilt 567 Tri-Axle Dump Truck (A50323)
2016 Peterbilt 567...
