Fallon
Super Member
I have a Kubota L3200 as does a friend. She has 40 acres they are going to be building on (daughter has 40 acres next door as well to be built on in a few years as well & is needing a backhoe. I'm guessing maybe averaging 100 hours of work a year over the next 10 years, probably with most of that in the next couple of years. I'll probably borrow it occasionally, but that's not my main concern at all. Other than me borrowing it, or hauling it to a mechanic (if it can't be worked on onsite) they really shouldn't have any need to transport it. I don't think it will be called on to do much if any stump removal (think the biggest tree on the property is maybe 12" down near the creek, but none near the building site). Ditches, maybe some trenching, maybe some digging out of some knee high Yucca. The house building & foundation work will all be done by the builder not her.
She's owned a Terramite & Mahindra tractor with a Mahindra backhoe (not sure what model, slightly smaller than our L3200s) previously. She really like the Terramite a lot & was defaulting to looking for another one. The Mahindra wasn't that great or sturdy of a tractor, but she ran the manual crash box on it just fine. While a good operator, she's not too mechanically inclined & much more than an oil change will require a mechanic (I'll probably help out with some small stuff to keep my borrowing privileges).
Budget is about $9k, which if my research holds would cover these 4 options. I'm pretty mechanically inclined, can do a decent inspection on a machine & will probably help her when acquiring it. Acquisition time is probably before winter, so there is time to hunt for a good deal & good equipment on all options.
A used Terramite or similar (mini backhoe)
An old real backhoe (1975 Backhoe 4500 Ford��DRASTICALLY REDUCED��**Quick Sale Needed* was the one that set off this discussion, although there are others around)
Backhoe implement & subframe (Kubota, Woods, etc.) to strap onto her L3200
An older used mini-excavator
What would you guys recommend?
I think the main contest is between an old real backhoe & a not quite as old Terramite. Are the maintenance issues on an older backhoe likely to be a significant challenge? Are parts going to be a big challenge? I'd like to recommend an older hoe for the greater functionality, but wonder if the maintenance issues would be to much.
- Pro's: She's owned one before & liked it, a little more loader capacity than our L3200s, spare machine if you get the other stuck, relatively easy for me to borrow,
- Con's: Doesn't bring that much to the table over her current tractor other than the hoe
- Pro's: Way more digging power, Way more lifting power, way more pulling power, you can't beat a heavy machine for just getting any tractoring job done, TractorData.com Ford 4500 industrial tractor information says it's about twice the machine our L3200s are depending on how you measure
- Con's: Old machine may need repairs & have hard to find parts, another machine to maintain, maxes out my tow but not trailer capacity if I'm borrowing it
- Pros: No extra machine to maintain, relatively easy for me to borrow, a couple grand cheaper (more so if we happen to find a used one)
- Con's: have to hitch & unhitch, no spare tractor when you are stuck
- Pro's: I think they are cool:cool2:, optimized for digging
- Con's: She isn't excited about one at all every time I bring one up so it's probably not likely :thumbdown:, slow transport speed, another machine to maintain
