Backhoe lifting tractor ... digging force?
   / Backhoe lifting tractor ... digging force? #1
boostmg
Pennsylvania
Branson 3620 TLB Hydro
Alright so I watched a video of a guy who has a mahindra 2638, he said one big reason he bought it is because his hoe would lift his tractor .. i guess so he could move the machine by pivoting it?
I thought this was actually a really good thing to look for. My question is .. how is this calculated? Do you look at the hoe's digging force? And then the tractor weight?
I do see the mahindra 2538 tractor weights around 3k and digging for is 3.4k lbs ... i was also looking at the TYM 394/354 and that machine weight 3k lbs and the hoes digging force was 2600 lbs maybe?
   / Backhoe lifting tractor ... digging force? #2
Often times I see ads selling heavy equipment with loaders and industrial backhoes up in the air. Demonstrates strong hydraulics I suppose. But a compact tractor with removable backhoe should probably stay on the ground. Even with a sub-frame, the chassis is not designed for those forces.
   / Backhoe lifting tractor ... digging force? #3
There’s no good way to test it besides actually doing it. It would take a pretty wimpy hoe to fail that test.
   / Backhoe lifting tractor ... digging force? #4
To answer your question.....YES.
When digging, you might need to adjust sideways. (the way I do it is)... Draw backhoe bucket in to near the back of machine (industrial in my case), don't want it too close, don't want it too far. Push bucket down, which will lift tractor up. Rotate bucket the opposite direction you want to go and you will go in your intended direction. Raise bucket (which lowers tractor back to ground) and continue digging.
It's not a big deal. First time you do it, it might be a bit unnerving as you are now posted on two points.... loader bucket and backhoe bucket so you might (will) feel the machine wobble a bit side to side. You don't want to jack yourself up in the air, simply lift the weight off the stabilizers.
I did that once, had a neighbor who was watching me dig (people always like to watch dirt being moved it seems......including me when I was younger!)
Anyway, he did some ooh's & aah's when he saw me move the back around like that (crabbing it). I didn't think much of it but he had never seen anyone do it.
I'd agree with above....if your hoe is decent at all, I'd expect it to lift the back up, not a big deal.
Disclaimer: I don't have any experience with tractor backhoes, just the industrial.
   / Backhoe lifting tractor ... digging force? #5
:thumbsup:
Excellent advice! CUTs and SCUTs are great tractors but certainly are not on par with industrial heavy equipment machines.
   / Backhoe lifting tractor ... digging force? #6
Tractor backhoes and real backhoes aren’t in the same league but my tractor backhoe could still lift and move the backend sideways with loaded tires.
   / Backhoe lifting tractor ... digging force? #7
In the old days when pro backhoes where built on std tractors it was designed so that the frame tok all the force of the digger, the tractor just sat in the frame for power and transport, it was common to lift the wheels of the ground so you spared axel and tires, ordinary tractor tires was soft and had almost no resistance against cuts from rocks etc so that was a pain.
   / Backhoe lifting tractor ... digging force? #8
Tractor backhoes and real backhoes aren稚 in the same league but my tractor backhoe could still lift and move the backend sideways with loaded tires.
Yes, probably not good for the subframe...I've done it, my tires are loaded also...after thinking about it, I try not to.
   / Backhoe lifting tractor ... digging force? #9
There痴 no good way to test it besides actually doing it. It would take a pretty wimpy hoe to fail that test.
Exactly what I thought as I read the OP's question. Lifting the tractor with the hoe - AKA crabbing - should be possible if the hoe is sized right for the tractor. I've used crabbing to position the tractor over a trench that would be difficult to drive around due to obstructions at the work site and that needed to be a little deeper than it was to get a good slope to the pipe that was going in. If there's any doubt about the hoe's ability to lift the tractor, I'd insist that the seller demonstrate that it will do so.
   / Backhoe lifting tractor ... digging force? #10
A tractor with a backhoe that wont lift the tractor isn't of much use. You do need to be able to lift the tractor to reposition if needed, like when you are finished digging a ditch and want to get the tractor rear wheels back across the ditch or vice versa. I dont think I have ever seen a backhoe that would not lift the rear wheels however much depends on where the backhoe bucket is positioned. It would take strong hydraulics to lift the tractor with the boom and dipper fully extended and that might put much strain on the frame if attempted although the same amount of stress might be put on the frame when digging in extremely hard ground.
I try not to put too much strain on my TLB if possible, but I did buy it to dig and using as much force as the hydraulics will produce should not hurt the TLB if it is sized and designed correctly. Gradually increasing force as when using the hydraulics is not nearly as damaging as sharply impacting the ground/rocks with the bucket which I see being done a lot with commercial units.
1266 (A50490)
1266 (A50490)
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
19009 (A48082)
19009 (A48082)
71058 (A49346)
71058 (A49346)
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
1997 John Deere 8100 MFWD Tractor (A51039)
1997 John Deere...
