F1520
I'm getting ready to add a backhoe to my 1520 and I have a question about backhoe hydraulics that I haven't seen answered here already. I understand the usual way that backhoes are hooked up by diverting the flow from the PB port on the loader control away from the manifold block, to the hoe, and then back to the return port inboard of the right rear wheel. Thanks to all, especially RickB :thumbsup: for many informative posts and pics on this topic.
Is it possible to run hydraulics to a backhoe such as a 757B from the rear remote ports? Can the two hydraulic lines from the backhoe simply be connected to these remote ports?
Specifically, I'm wondering about the two plugged ports on the underside of this block that are visible in the inspection mirror, and in the second pic with the remote lines installed. If these lines are already there, is it simply a matter of connecting the QDs from the backhoe? And if so, which one is pressure to the hoe and which is the return?
Thanks!
Thanks!
