Backhoe hoe replacement...help!
   / Backhoe hoe replacement...help! #1
hwinch5
Hamden, CT
Gravely, Model L, Ford 2000 Industrial backhoe
My 1964 Ford 2000 Industrial backhoe hoe broke today while digging out an 8 yr old oak stump! Ouch...Any recommendations for replacement? What to look for, what to avoid & how to make sure the replacement is exactly what I need. It's an 18" bucket with 4 teeth. :confused: Thanks for the help,
   / Backhoe hoe replacement...help! #2
how about a lil more info other than 'it broke'
what broke?
   / Backhoe hoe replacement...help! #3
what broke?
   / Backhoe hoe replacement...help! #4
The easiest way to find a replacement is to measure the diameter of the pins on the bucket, the distance between the ears for both pins, and the distance center to center of the pins. This combined with the size of bucket will help.
   / Backhoe hoe replacement...help! #5
what broke? Might be it can be fixed.
   / Backhoe hoe replacement...help! #6
Are you saying the bucket broke? Or the hoe broke? If it's the bucket, how about a picture. I've seen them brake where they kinda look like a torn can; and where they pin to hoe. If it is just a bucket that is broken you can either heatnbeat into shape and reweld or start hunting for new.
   / Backhoe hoe replacement...help! #7
yup.. need more info.. but no info from OP ??
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51243)
2024 INGERSOLL...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
Quick Attach Pallet Forks (A47384)
Quick Attach...
