Backhoe backhoe for tn60
   / backhoe for tn60 #1
kje383
SE Oklahoma
hello,i am in the market for a backhoe for my tn60a. It has a loader on it now, from what i have seen the only company that makes a subrame for this tractor is Bradco. Most dealers tell me it is not nesesary for this size tractor. I have a full belly pan "skid plate" on this tractor and i don't think the subframe would fit with it. I am seriousley considering a bushhog 950 3 point hitch hoe. Any comments or sugestions would be apreciated thanks.
   / backhoe for tn60 #2
I would say go with the Bradco and modify your skid plate for the sub frame, or just take pieces of it and attach to the subframe. I am buying a Mahrindra 6520 4WD with a KMW skid steer loader and a Bradco 511 backhoe. The BH came in last Sat. to my dealer and has more features and is beefier than I realized. The 6520 has came in also, but is waiting for the loader at Mahindra's facility. Go sub frame if you like your tractor.
hugs, Brandi
   / backhoe for tn60 #3
The sub-frame won't hurt it none but with this size of tractor you really do not need one. So I guess it depends on how much more the sub-frame would add to the cost as well as reworking your belly plate.
   / backhoe for tn60 #4
You should do a bit of homework and talk to the dealer about the need of a sub-frame of just going with 3-pt. Some tractors require a sub-frame to keep your warranty. It's often smart to follow their instructinos. Damage to tractors with light infrequent use is rare. But make no mistake, the extra stress from a hoe is adding to the cumulative wear and tear. There is less W&T with a sub-frame.
jb
   / backhoe for tn60 #5
A subframe is not needed for a backhoe on a TN60. Indeed, New Holland doesn't offer a subframe for a TN60 as an option with their backhoe--3pt only.
Subrames are musts on all the TC series, but once you get to a TN the castings are strong enough to withstand the stress of the backhoe.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2019 KENWORTH T680 SLEEPER TRUCK (A52141)
2019 KENWORTH T680...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
2024 KRUZ Ravens Tri Axle Dump Trailer (A47384)
2024 KRUZ Ravens...
