I can not believe that Kubota would design a hoe for the
B2400 that would break it in half or otherwise damage the tractor if used properly.
Part of the installation of the 4672 is a subframe mounted on the tractor that stays attached to the tractor even when the hoe is removed. This would increase the strength of the tractor frame without the hoe attached. There are 2 versions of this subframe, one is compatable with a belly mower. There is also a much stronger top link bracket that beefs up that area as well, including when the hoe is removed.
I also have a
B2400 and compared the Kubota 4672 to the Woods 6500 and concluded that the Kubota hoe was the better one.
Both hoes attach to the
B2400 on the lower 3 point pins. The Woods subframe attaches on the pins but requires removal of the lower arms first. The Woods subframe still has the force of the hoe come through these 3 point pins.
Some of the differences between the 4672 and the 6500 are:
The Woods subframe stays attached to the hoe and will require more floor area to store.
The Kubota 4672 has 13% more bucket digging force and 36% more dipper stick digging force than the 6500! (4672 has same digging force as the 4690)
The Woods 6500 does not have replaceable bushings (the 7500 does have replaceable bushings but should not be used on the
B2400).
The 4672 has more reach, higher loading hight and costs the same as the 6500.
The Kubota hoe is the same brand as the tractor and may be more desirable at resale time.
Hope this helps,
Andy
