Backhoe Cub Cadet 408 Subframe Modifications
   / Backhoe Cub Cadet 408 Subframe Modifications #1
JBjunior
Bronze Member
All Over
Kubota L35 TLB/Mahindra 3016
There is a Cub Cadet 408 backhoe for sale locally with subframe. I know it is a Woods 7500 with a different color paint. It has a subframe off of a Cub Cadet 7265. I know this is a wild card question, but anyone that has any information is greatly appreciated. I am wondering how hard it will be to modify the subframe to work on my Mahindra 3016 (2013 model). It is a similar size/weight tractor but I know there will be differences. I am not sure what years the Cub Cadet tractors were made by Mahindra, and regardless they are roughly a decade apart in production. Any thoughts?
   / Backhoe Cub Cadet 408 Subframe Modifications #2
Anything can be modified or made to fit anything.. just a question of how much work it will take.
I don't know your tractor or that particular cub backhoe but something's I would verify is if you have a continuous hydraulic exit (if the backhoe needs it, after all it could be pto powered with its own pump).
Secondly are you getting a great deal on it? Sometimes it sounds great because you are paying 3k instead of 7 but factor in all the work, hydraulics, wear and tear parts that may need replacement and something that's New would only be a couple hundred more but a guaranteed fit.
Lastly, being that you know that it's a woods backhoe, why not give them a call and inquire how much a subframe will cost for your tractor? Less work. And you could always sell the used subframe or use it for another project.
Just throwing a couple of ideas out there..
Shui, I appreciate the response. Hydraulics are the easy part, I have installed a 3rd function recently so I am familiar with the workings on my tractor and I "used to be" a hydraulics system technician.
I wouldn't consider it if it wasn't a good deal :). I am looking at anywhere from around $5K for a 3 point mount to around $8K installed for a subframe mount backhoe. I can purchase a 3 point mount backhoe and then purchase a Wallenstein subframe mount for $1200 and be mostly done for $6200.
I verified earlier this week that Woods does not make a specific subframe for my tractor, though I will call them to see if they have any data.
A follow on question would be how different are the Mahindra 3015 and 3016 frames?
I think I answered one of my own questions:
3016
Length: 121.3 in. (3,080 mm)
Width: 63 in. (1,600 mm)
Weight: 2,437 lbs.
3015
Length: 115 in. (2,920 mm) with Industrial tires
Width: 60 in. (1,524 mm) with Industrial tires
Weight: 2,601 lbs.
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2013 Case IH Magnum 315 MFWD Tractor (A50657)
2013 Case IH...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
Small concrete mixer (A49461)
Small concrete...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
