BACKHOE BUILDING PLANS
   / BACKHOE BUILDING PLANS #1
avz
Hi people
I would like to build a towable backhoe and since I dont want to renvent the wheel, I would like to ask if anybody has plans, detailed pics, other ideas that you will be willing to share. let me point out that I have the tools to do it, so that's not the problem.
Thanks.
   / BACKHOE BUILDING PLANS #2
   / BACKHOE BUILDING PLANS #3
there is a thread ( cannot off hand remember where) on tbn and to give the author credit he made a very good point, keep in mind you are not trying to compete with a full size backhoe but are trying to be more cost effective than day labor, I built a towable backhoe several years ago, bronze bushings, etc, etc, after I completed my project (about 10 hrs of work) the machine sat for several years without use, I never loaned it out due to liability issues, and made the purchaser sign a waiver, now my .02 cents save your money on bushings/grease joints,and snazzy/complicated torch/plasma cutout parts, invest that money in good hydraulic components, my recommendation is to weld grade 8 or harder washers at the pivot points, use grade 5 bolts and check them for wear, my friend did this, bolts show no appreciable wear after 100 hrs of use, use common channel to make your bucket, look at lackender backhoes to eliminate the linkage at the bucket Ie: less pivot points/less things to wear out, I would not fool with making a curved main arm either the added benefits far out way the aggravation of getting everything lined up correctly and straight when assembled, unless you have access to a machine shop with wood fixtures, unfortunately I have always leaned towards functionability compared to cosmetically appealing, check with surplus centers for quality hydraulic products, keep it simple,an if in doubt build it stout,
Thanks for the detailed response. I will make use of the advice, specially since they are coming from a person that is experienced about the issue.
   / BACKHOE BUILDING PLANS #5
You'll have to buy your own plans but this guy has one of the best guides I know of:
search for 500passwords on www. youtube . com
   / BACKHOE BUILDING PLANS #6
On machinebuildersnetwork dot com in the members services section-go to : plans- tractor plans- backhoe plans . I havent downloaded them yet . There is a backhoe building forum on machinebuildersnetwork also.
Dave
   / BACKHOE BUILDING PLANS #7
I have received some excellent suggestions on this thread.
I hadn't heard washita's advice yet, though, about the grade 8 bolts and grade 5 washers. I'm going to seriously look into that.
   / BACKHOE BUILDING PLANS #8
   / BACKHOE BUILDING PLANS #9
Thaks a lot IPF!!! Another web-site to keep me up all night!!! :D
   / BACKHOE BUILDING PLANS #10
There are some very talented builders in that group. I like the interface of this site better, but I do like how the Yahoo groups have the option to store files in a central location for access. It would be nice to have that here too. How many times have members answered the "what are standard measurements for Cat. 0 vs. Cat. 1 3 pt. Hitches" question. I'm sure there are plenty of others too.
Maybe Muhamed is monitoring and will see the suggestion.
Avant 420E (A42021)
Avant 420E (A42021)
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A45046)
2019 ALLMAND BROS...
2012 WESTERN STAR 4900 WINCH TRUCK (A45046)
2012 WESTERN STAR...
2024 P.J. Trailer, VIN # 4P53F4924R1407534 (A44391)
2024 P.J. Trailer...
More info coming soon! (A44572)
More info coming...
2019 MACK PINNACLE DAYCAB (A45333)
2019 MACK PINNACLE...
