Backhoe Backhoe Bucket Backwards, Can you?
   / Backhoe Bucket Backwards, Can you? #1
OrangeBeast
Bronze Member
Northwestern Vermont
Kubota BX22
Ok I know this is a strange question but can you install a BT600 bucket flipped 180? and it be functional?
   / Backhoe Bucket Backwards, Can you? #2
I am trying to work on this one but you are really making my brain hurt. :)
   / Backhoe Bucket Backwards, Can you? #3
I know you can turn the bucket around on many trackhoes with quick attach hitches on them.
   / Backhoe Bucket Backwards, Can you? #4
Why? Could you even empty it when filled? It dosent have a clam like a shovel! Now I wanna go try!
   / Backhoe Bucket Backwards, Can you? #5
Have you tried it? Does your setup allow it eithout modification? I understand why you want it to work. Are you trying to dig a wall and the depth wont allow you to dig from the top side?
   / Backhoe Bucket Backwards, Can you? #6
Like this video I found.
Ya like that but on a BX kinda scale.
I am working on adding buttress supports to a foundation that is only basically on grade! What the original owner was thinking who the heck knows. So over the summer I had no problem digging the 4' down in the clay but I was having difficulty getting under. And wow is it hard to do with a shovel. Right now I dont have the BH on as I am about to set up the tractor for winter. This just popped into my head so I wanted to see if anyone tried this but a search came up with all kinds of BH stuff but did not see anything on flipping the bucket around and using it that way. I know its not designed for it, but its was a thought, and it would not be to do the entire hole just finish it up. I have 2 done and I have 8 to do next summer and frankly any way to make it easier i'm all for it.
I don't mean to make anyone's head hurt or explode on thinking about this.
   / Backhoe Bucket Backwards, Can you? #8
Like i said, can you get your setup to do it? If you can, than do it. Your not gonna hurt anything. Just do it if you want. Seen it done a handful of times to dig lower walls. Its not something out odf the ordinary
   / Backhoe Bucket Backwards, Can you? #9
Shortthrow 50,I find your avatar and other picture to be very offensive and childish.I am surprised it is allowed.This forum is supposed to be about tractors.
   / Backhoe Bucket Backwards, Can you? #10
I don't know but I wonder if the hydraulics and boom are designed for working in that direction. But for gentle use it might be okay.
Now back when I was a kid, that's the way the power shovels worked (they ran off of cables not hydraulics, and had trap doors in the bottom for dumping.)
Ken
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
2015 Chevrolet Tahoe SUV (A49461)
2015 Chevrolet...
2006 John Deere 310SE 4x4 Loader Backhoe (A49461)
2006 John Deere...
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
