Backhoe Backhoe blade
   / Backhoe blade #1
19977
Smyrna,Delaware
JD 4520
Has anyone made a back blade attachment in place of there bucket scoop,so they can be switched back and forth.I hope I explained this so it's understandable. Thanks Mike
   / Backhoe blade #2
Got a thumb ?
With the aid of a thumb, you can grab a beam or wood post and blade away.
That's what I use, works great.
   / Backhoe blade #3
I took a piece of metal and welded a tab to it and then a bolt through the bucket. the metal covers the bucket teeth and gives you a smooth edge. Mine is only as wide as the bucket, but you could make it wider...
   / Backhoe blade #4
I see there is a squeegee type of blade that attachs to bucket to save time backfilling, but not sure who makes it. plowking
   / Backhoe blade #5
gradall makes just such a thing as an attachment for there excavators. i never used one so cant say how well they work but i personaly like the 5ft wide bucket which has no teeth for grading off and backfilling with my gradall excavator, its like having a 5ft wide blade but you can also still pick up material with it and move it around. any larger areas that arnt too steep its faster to do with the dozer
1270 (A50490)
1270 (A50490)
(6) 11R22.5 DRIVE TIRES (A51244)
(6) 11R22.5 DRIVE...
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX 3,200lb. 1.5 Ton Crane Mechanics Truck (A50323)
2019 Ford F-350...
JOHN DEERE 3020 TRACTOR (A51243)
JOHN DEERE 3020...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
