Hi, I'm a new member and new to tractors in general. I inherited a property of 5 acres recently and am beginning a small family (non-commercial) farm. I have a Yanmar FX 24D in very good shape with only 340 hours on it. I'm having trouble finding specs on this grey market tractor. Specifically I am trying to determine if it will accommodate a small backhoe attachment. I'm looking at the WoodMaxx BHM5600 6', which weighs in at just under 1000 lb with thumb, operates with 3 point tractors in the 16-25 HP range.
My Yanmar brings 24 HP to the PTO, 28 to the engine. I do not know the lift capacity of the PTO, there is limited info on tractordata.com or anywhere else it seems. The weight of the tractor is 2623 lbs. Has 3 point hitch. Has wheel base approx. 65". Currently equipped with a 300Kg front loader.
The dealer I bought it from, who primarily deals used Yanmars, stated it'll work with a small backhoe unit without causing damage to the tractor and without the need for a subframe. He stated he has sold hundreds of older yanmars and has known several people who run a backhoe attachment for years, even on lower power units like the YM2210, without using it super gingerly and have seen no issues. Yet I have heard from others that a backhoe unit on an old 3 point Yanmar may split the tractor in half if it doesn't have a subframe.
My uses for the backhoe will be fairly light duty: digging out roots of smaller trees and shrubs, picking smaller boulders, and digging a 300' 16"- deep trench for fiber optic cable.
I'm looking for a confident answer. Does anyone have direct experience with this? Can I operate a 1000 lb backhoe attachment on my Yanmar FX24D without engineering a subframe? (not sure if I currently have the skills to create such a thing)
I do not need it to be 100% risk free usage, but within a reasonable risk tolerance for the applications I'll be using it on.
Thank you
Thank you
