Backflow and Filters - Well System
   / Backflow and Filters - Well System #1
SLOBuds
Los Angeles/Central Coast, California
Kubota L35
My small farm irrigation system is growing leaps and bounds. I am adding storage tanks, line drops to fields, plus I am planning on a new house for the parcel.
The system now involves one (off property) well, a booster pump and pressure tank at the well, 2 storage tanks net 7000 gallons, two additional booster pumps and pressure tanks at the parcel.
Two questions:
1. Do I need backflow preventer/s, and where would it/they go? I would like to install one only if that is possible.
2. What kind of filtration devices should I be considering. I am not talking about domestic water filtration (already taken care of). I am asking about filtration before the water tanks, or before the lines set in my fields for irrigation, or others.
Thanks,
Martin Petersen.
   / Backflow and Filters - Well System #2
I've been using one of these for 13 years. Seems to work good. Good for lots of flow and easy to pruge. Rusco filter
Cheers!
   / Backflow and Filters - Well System #3
I can only say what is required in my area.I f you connect an irrigation system to your house water you have to add back flow preventer to prevent any tainted water from being introduced into the potable system.
2022 CATERPILLAR 303 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
