BACK HOE STABILIZER PAD EXTENTIONS?
/ BACK HOE STABILIZER PAD EXTENTIONS? #1
escavader
Veteran Member
western maine
bx-23 ,
hello,
Has anyone ever built extentions for their stabilizers.I noticed mine sink so much some time,im down on my tires again,with no more adjustment left.Was thinking of a 4 inch extention somehow.Anyone done it for your KUBOTA?
ALAN
/ BACK HOE STABILIZER PAD EXTENTIONS? #2
hello Allen, you don't need extensions. when you put your stabilizers down you shouldn't lift your back wheels off the ground. only down far enough to stabilize, not lift. lifting causes unneeded strain on your frame. this should help with the sinking. however if that doesn't help you could add on some wood blocks. good luck.
-Matt
2PT AUGER W/ SHAFT (A64280)
2PT AUGER W/ SHAFT...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61572)
2024 Kubota...
2010 Chevrolet HHR SUV (A61574)
2010 Chevrolet HHR...
40' New Container (A62679)
40' New Container...
Bulldog 10000lb Jack (A63117)
Bulldog 10000lb...
KUBOTA LA535 FRONT LOADER ATTACHMENT (A64280)
KUBOTA LA535 FRONT...
