Snow Blade Back drag front plow
   / Back drag front plow #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
I'm new to the snow area and plowing and have a front plow question- I've had one dealer tell me you can't back drag with the front plow because of the spring release and another dealer tell me that back dragging is not an issue with the spring release.
Those of you who use the front plow for snow- Does back dragging work with the spring release? I'm assuming I'll have to back drag a bit in front of the garage and shop doors so it won't be massive amounts or for long distances.
Thank you for the replies!
   / Back drag front plow #2
You can back drag some lighter snow. If it's frozen, super heavy packy snow your blade will likely ride up and over it. The plow mechanism lifts but it doesn't hold the blade down with pressure.
   / Back drag front plow #3
Are you talking FEL mounted or automobile mounted?
FEL plow
   / Back drag front plow #5
Then I don't think post #2 regarding down pressure applies.
I'd think the plow manufacturer would have some advice in this regard.
   / Back drag front plow #6
I agree with post 2. The cutting edge usually isn't working in your favor. Back dragging is always a hit and miss thing.
   / Back drag front plow #7
I think he's asking about problems with the spring release/trip.
Down pressure from the loader and even just the blade weight works fine for me to pull snow away from the garage (etc).
I've never used a plow with a trip mechanism so hopefully someone will chime in to actually answer the OPs question. Lol.
   / Back drag front plow #8
Usually you can apply down pressure just like you would with a bucket on the front, or if your fel has a float position it will not have down pressure. in any case the springs on the plow are made to trip going forward, so i don't think it will trip going backward. The previous posts are correct in backdragging isn't done as well since the cutting edge is made for going forward.
   / Back drag front plow #9
Full blade trip and edge only trip mechanisms do not affect back dragging on any plow I have used or seen. As far as how well it works that depends upon a lot of factors like snow depth / density, blade weight, down pressure, etc...
   / Back drag front plow #10
I have two blades, loader mounted. One with whole blade trip and the other with just the edge. Neither effects back dragging in any way that I know of.
John Deere 1025R (A42021)
John Deere 1025R...
2001 Car Mate 16ft Enclosed T/A Trailer (A42742)
2001 Car Mate 16ft...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
2020 Chevrolet Equinox LS SUV (A42744)
2020 Chevrolet...
2013 CAR MATE CUSTOM CARGO TRAILER (A45333)
2013 CAR MATE...
2014 CS&P  BLENDER (A45333)
2014 CS&P BLENDER...
