Bachhoe subframe for KAMA 554
   / Bachhoe subframe for KAMA 554 #1
psj12
Platinum Member
Short OK
KIOTI 551
After having read many posts here and on other forums about mounting backhoes on three point hitches versus subframe mounts I am leaning towards wanting to mount my JW7 backhoe to my Kama 554 using a subframe.
Does any one produce a subframe mount compatable with a Koyker loader on this particular tractor? I have written Koyker with this question and am waiting on an answer. Does any one have plans for, or photos of one they have made? Any help would be appreciated.
   / Bachhoe subframe for KAMA 554 #2
I have a simaler problem/issue. I have a KAMA 454 and a old Ford 758 BH I'm restoring. The BH has frame members 36" long, 1/2 x 4". They start at the lower pins for the 3PH. This goes back to just under the axel but, inside the ROP /FEL frame. I was planning to make a heavy member tieing the FEL/ROP in line with the axel. Then I will weld the BH frame to this pc. The BH also has a diagonal member that goes up to the top link. This is not adjustable and installed inplace of the the top link adjusting link. Since the lower arms can raise. the BH is rigidly mounted at two places, axel/ROP/FEL frame and top link hole.
I have not started and would like to see detailed photos of other subframe methods before diving in
Patrick
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
UNUSED FUTURE D45 HYD POST DRIVER (A51248)
UNUSED FUTURE D45...
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
