B9200 MMM not raising evenly
   / B9200 MMM not raising evenly #1
ckx
Kubota B9200HST
I have a B9200HST with belly mower... The deck does not seem to be lifting evenly. The right side barely lifts up with 3 pt completely raised. The left side of the deck lifts, but not quite as much as I would think it should... This is an RC-60 deck.. Any help would be appreciated...
   / B9200 MMM not raising evenly #2
Here is the manual 70732-71110 and is SS by 70732-71113 see if that well help.
   / B9200 MMM not raising evenly #3
If the linkage is adjusted properly and both arms are comming up at same rate, does the deck have a balancer on it? If it does are the springs torqued down evenly or is there something jammed underneath the balancer making things uneven.
David Kb7uns
I believe the linkage is adjusted properly.... I only see 1 rod that can be adjusted on the left side that goes back to the lift arms... I will have to measure that arm and see what it is. There is not a balancer or springs. I just cannot figure out why the right side is not lifting as it should... I do not see anything bent or binding when raising the deck. The right side lift chain looks looser than the left side... I will look into it a little deeper later today... I thought maybe someone had seen this before and could give some advice of where to start looking....
Thanks!
   / B9200 MMM not raising evenly #5
I don't know if your 9200 deck is the same as the 7200. Is there a lift bracket on each of the 3pt arms that goes to lift the deck? The right side would be the adjustable 3pt arm and maybe the turnbuckle has turned. Are your 3pt arms level? Maybe try adjusting (shorten) the right side 3pt arm and it should raise your right side of the mower. I also believe there were notches in the framework where the lifting brackets could go into which may not be lining up. My lifting brackets (that raise the mower deck) were bent a little, which looked easy to do.
Let us know, or maybe a few pics might help. :thumbsup:
There was just 1 lift bracket on the left hand side... I think the turnbuckle must have vibrated loose on the lift rod as the stop bolts were not even close to the upper links... I adjusted turnbuckle and it seems to be close now... With deck all the way raised I only see about 1/2" difference between left and right... I did not see anything bent... I appreciate the guidance....
KUBOTA 1140CRX RTV (A51406)
KUBOTA 1140CRX RTV...
Tarter 2 Horse troughs (A50860)
Tarter 2 Horse...
2022 Club Car...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
STORAGE FEES (A51222)
2803 (A50460)
2803 (A50460)
