B7610 Question
   / B7610 Question #1
Dascro
SW Pennsylvania
Kubota B7610, Cub Cadet 1450
For the those of you that use a B7610, do you notice a change in sound between when the clutch is engaged versus when it is disengaged? Not saying it is a bad sound, but I can clearly hear a change in sound coming from the clutch housing. Everything else seems fine its just there is a change in sound when the clutch is released versus when its engaged.
Just wondering if this is normal?
Dave
   / B7610 Question #2
I can hear a difference in sound on my B7510HSD and suspect it is normal. I have about 32 hours on mine and it is either quiter or I am getting used to it.
   / B7610 Question
Thanks for the input Caddelma.
I suspect it is normal too, but just looking for some input from others to confirm one way or the other.
I have close to 90 hours on mine and it does seem to be getting quiter with time.
   / B7610 Question #4
I also have a B7610 same here.Push in the clutch disconnects pto and also hydrostat drive portion of pump I think.I have been told hydro pump is two section.Anyway this is normal,no worries,WORK IT!!
   / B7610 Question
Thanks maxquest,
I appreciate your input. I do work it pretty good, but like to make sure everything is in proper working order too. I want to be able to work it hard for many years. :D
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
