B7610 Mulch Deck?
   / B7610 Mulch Deck? #1
hagman
Central, IL
B7610 Kubota
I recently purchased a set of the Gator mulch blades and have to say it made a huge improvement over the stock Kubota blades. I asked my dealer if Kubota made a high lift blade for my 54" deck (RCK 54-24B) and he said no. I am considering blocking off the discharge side of the mower to see if the deck would mulch better. My X585 J.D. required a different deck for mulching so I'm not quite sure whether blocking off the discharge chute on my B7610 will work or not. Asking around locally I got mixed opinions on the subject. Has anyone tried to change a side discharge on a B7610 to a mulch deck? And has anyone tried to order high lift Kubota baldes for the same tractor? I'm having a hard time believing that they make them for a 60" deck from reading other threads but not for the 54". If anyone would know it would be you folks. I gain more knowledge on a daily basis about Kubota through this website than any other source out there. Thanks.
Hagman
   / B7610 Mulch Deck? #2
I tried making/useing a mulch plug on a 60" MMM on a BX23 and got mixed results. If I stayed on top of the mowing and didn't try to cut off no more than an inch and went slow it did fairly well. Wet or soggy grass was a no no.
I didn't have gators nor did I get around to trying a set of Kubota's mulching blades so needless to say it didn't do very well with the leaves and I ended up going with a Cylone Rake bagger.
It may work with the gators.
Volfandt
http://www.tractorbynet.com/forums/...-bx-60-mmm-mulch-plug.html?highlight=volfandt
2020 KENWORTH T880 ROLL OFF (A51222)
2020 KENWORTH T880...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
