B7610 hyd
   / B7610 hyd #1
Suess
Bronze Member
Minnesota
When I check the hyd oil When I first pull out dip stick it's dry but after I put it back a pull it out again it shows slightly over full. Is this normal? It checks consistant each time after the fist check so I have been trusting the second check as correct and I have had to add oil a few times. But still I wounder?
Has any one added a better oil cooler to a 7610 or similar? The warning light has never come on but the oil does get hotter than I like to see. Thanks
   / B7610 hyd #2
For what it is worth my tractor does the same thing. Dry the first pull then normal after. I never even look at the stick the first time when checking it now. Clean it off, put the stick it and read it from then is how I do it.
   / B7610 hyd #3
Mine has always done the exact same thing. The only reason I have ever come up with is the tube the dipstick drops into must get air locked, then when you pull the stick, the oil enters the tube. I could be totally off base on the reason why but your dry mystery stick is normal.
   / B7610 hyd #4
I posted on this about two years ago. Same with my B7500 and B7510. I even tried to clean the vent tube. Do the double sticking check now, too. I did color the "safe" area with a black felt tipped permanent marker, too, and it makes reading the level a whole bunch easier. The marker hasn't come off in a year, either. Try it. You'll like it.
   / B7610 hyd #5
I have a B7510 and noticed the same thing. Thanks for alleviating my fears that there was a problem. I'll do the dip stick double take for now on!
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
