B7610 Block Heater
   / B7610 Block Heater #1
CurtisB
Bronze Member
NW Minnesota
Kubota B7610
Hi, I recently relocated back home to Minnesota and now need to install the block heater in my Bota. Anybody know the P/N for the 7610?
Thanks.
Curtis
   / B7610 Block Heater #2
The Kubota part number is 70000-73274 for all B-Series Kubota's except the B7400 and B7410.
   / B7610 Block Heater #3
Depending on the age of the tractor, now might be a good time to do a drain and refill of the cooling system. I prefer the new premix bottles, so I don't have to worry about contaminants in the domestic water supply being introduced to the tractor. I could buy distilled water, but there isn't that much of a cost savings in the end when you consider the little that you will use and the time it takes to mix etc. Dusty
   / B7610 Block Heater #4
Make sure you get the correct allen socket for the plug. It is a real pain to unscrew the plug. Kubota grey paint on the block sticks pretty good . . .
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2005 STERLING LT8500 SERIES MIXER TRUCK (A50854)
2005 STERLING...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
