B7610 backhoe hose replacement
   / B7610 backhoe hose replacement #1
mfc1010
ma
05 kubota 7610 tlb
I have a hydraulic hose on my b7610 backhoe that has sprung a leak is it a big deal to replace. I worry about bleeding the new hose and removing air. Can someone give me step by step instructions
Thanks Mike
   / B7610 backhoe hose replacement #2
Just make sure you have the cylinder locked, such as the boom resting on the ground, so when you remove the hose there is no weight or force on the cylinder. Otherwise fluid will shoot out (not safe). Replace the hose and cycle the circuit several times and air will be pushed out. Open center hydraulics are asy to bleed. Its not a closed system like car brakes. Wear safety glasses and gloves.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
1272 (A50490)
1272 (A50490)
2024 New Holland T8.410 MFWD Tractor (A51039)
2024 New Holland...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
71067 (A49346)
71067 (A49346)
