B7610 3 point hitch question
   / B7610 3 point hitch question #1
coho
Question on a new to me B7610. The three point hitch lowers rapidly. The manual states that the lowering speed can be adjusted with the knob centrally located on the operators platform by my feet. Well, it seems to be frozen and will not turn either way. The manual shows the knob with a half moon arrow where the "A" end is labeled "fast" and the "B" end is labeled slow to indicate the direction of rotation to adjust the lowering speed depending on intent. There is a dot, "C" to the right on the diagram labeled "lock". No indication of how to lock/unlock the knob. Is there a lock that I am not seeing on the tractor or does anyone have any suggestions on freeing up this mechanism without damage, if it is in fact frozen? Thanks.
   / B7610 3 point hitch question #2
Put a lot of PB Blaster on the threads... Works just like a water valve...When you screw it all the way in clockwise, it will shut off the flow of oil out of the cylinder and that will "Lock" the 3 point in the raised position because the oil will not be able to run out of the cylinder.... any partially closed position will slow the oil flow... KennyV
2014 Chevrolet Tahoe SUV (A49461)
2014 Chevrolet...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
TAKEUCHI TB210R EXCAVATOR (A51242)
TAKEUCHI TB210R...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A51039)
2018 Ram 3500...
