B7510 Tire Pressure
   / B7510 Tire Pressure #1
robertm
Veteran Member
Northern Illinois
Kubota BX2660
Well, with all the issues I have with my B7510 tearing up my lawn, I am trying everything before tossing my arms up in disgust and trading it on a BX2350.
What tire pressure should I use on the front (and rear for that matter) tires while mowing? I keep them aired up when using the loader. Could that be a problem? As suggested by a fellow TBN'er on my other thread, I intend on checking the front-end alignment, too, but in 200 hours I've seen no tire wear indicating a problem there.
  • Good Post
Reactions: fc1
   / B7510 Tire Pressure #2
I don't know what tires you have, but on my B7500 with turf tires, I run the fronts at 22 psig and the rears at 20 psig per the Operator Manual. I only mark the lawn when wet or in tight turns around trees, etc.
   / B7510 Tire Pressure #3
I have mowed our three acres since 2010 with a B7510. Its rear diff has a tendency to drag on sharp corners, even in 2WD. I break up corners by shifting fore and aft with the HST and then it doesn't cause trouble with the turf. My Bolens G174 does not do that; neither did a BX I had here for a while.
The B7510 (no loader) has proven a great workhorse around our 115 acres, though, running the mower deck, chipper, 4' bush hog, and hydraulic trailer. Its first mechanical repair (1650 hours) came on the weekend when I discovered that the seat supports tack-welded to the fenders had worn free. I replaced the four tack welds with bolts and the seat safety switch no longer refused my wife permission to run the tractor.
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
JLG MAN LIFT (A50322)
Farmall 460 Tractor (A50514)
Farmall 460...
