B7510 or B7610 Service Manual / Wiring Diagram
   / B7510 or B7610 Service Manual / Wiring Diagram #1
Semms
PA
Kubota B7510
Hi,
So I'm hoping someone can help me out. I recently bought a used b7510 TLB and have decided I need to add an alternator for work lights. I purchased a pdf version of the service manual and unfortunately it contains everything but pages 9-M1 and 9-M2 which would be the wiring diagrams. Does anyone have those pages or an equivalent wiring diagram? I don't even need a scan, a readable picture of it from a phone would work.
I'm working on adding the 40 amp alternator and wiring it the same way the wiring harness from the kit is wired and I'd like to check the diagram before I proceed.
Thanks,
Semms
   / B7510 or B7610 Service Manual / Wiring Diagram #2
Send me private message with your email and I'll scan in the pages and send them to you.
Mike
   / B7510 or B7610 Service Manual / Wiring Diagram #3
Hi,
Thanks,
Semms
Just a suggestion, go with LED’s and make no changes to your existing alternator/dynamo.
Good luck!
Thanks Mike, PM sent.
bg71361,
Thanks for the suggestion but the wimpy dynamo can only handle one of the LED light bars I installed. I have a 20" led light bar facing forward that draws 10.5 amps. I plan on adding 3 36watt led lights facing rear for backhoe work. One facing straight and one each off to the sides.
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2007 Peterbilt PB340 T/A Roll-Off Truck (A50323)
2007 Peterbilt...
2018 Infiniti Q50S Sedan (A50324)
2018 Infiniti Q50S...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
