B7510 ignition lights come on but starter doesn't engage
   / B7510 ignition lights come on but starter doesn't engage #1
Daves8ball
Salado, TX
Kubota L2350, B7510
I had inadvertently pushed the PTO lever forward and the tractor died.
When I turn the key to start position the light comes on but the starter does not engage.
It seems like a safety or kill switch has not reset not sure where they are beside the one on the PTO lever
The shaft spins freely so I know it is in neutral position
I checked the 5 fuses under the hood on the driver's side and all were good.
   / B7510 ignition lights come on but starter doesn't engage #2
Move/Wiggle the PTO lever back and forth while you turn the ignition key on and see if the starter tries to spin.
Sometimes the safety switch does not connect and moving the lever a bit gets it to connect properly. Also be sure you are sitting in the seat when turning the key as there is probably a safety switch there also.
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
1240 (A50490)
1240 (A50490)
