B7500hsd diff lock problem
   / B7500hsd diff lock problem #1
C4Ranch
Veteran Member
Eastland Co, Texas
Kubota L5240 HSTC
Hi, 1st post and need help. My diff lock peddel will not return up normally. I tore diff axle assembly apart and what is happening is the pin on the shaft is falling down when the peddle is depressed all the way preventing it from rotating back up. The dog clutch looks fine and I see some wear on the differential case teeth, but could that be it? Could they be worn so much its causing the shaft to over rotate allowing the pin to drop? I don't want to replace the diff housing at $100 if that's not it. Anyone with experience here or happen to have a diff housing apart where they could provide me some measurements of the theeth?
Thanks!
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2013 VOLVO VNM DAY CAB (A51222)
2013 VOLVO VNM DAY...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2006 Peterbilt 379 T/A Wet Kit Sleeper Cab Truck Tractor (A49461)
2006 Peterbilt 379...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2015 DODGE RAM...
