B7500DT
   / B7500DT #1
Anonymous Poster
Epic Contributor
Is there as much changing of transmission/gear fluid on the B7500DT as there is on all the Bx models' hydrostatic transmissions? I didn't know if there is a difference between a manual gear box and a hydro for the scheduled maintenance intervals? Thank you for any information.
   / B7500DT
Kubota manuals recommend the same interval service schedule across its entire line of tractors starting at 50 hrs. It is recommended that all hydraulic fluid be changed at this time. However it is especially recommended for hydrostatic transmissions. Also all Kubota tractor hydraulic systems use the same fluid which is in the transmission/differential. So there are those 3-pt hitch and loader pumps and systems to consider. If you love your Kubota, take care of her!
   / B7500DT #3
Another difference is the dt has 1 hydro filter where the hst has 2. I don't think the dt has a hydro filter screen either.
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
2018 Allmand Light tower (A49461)
2018 Allmand Light...
