B7500 true hp?/mower width
   / B7500 true hp?/mower width #1
abheye
Bronze Member
Western NY
1957 Case 311, Cub cadet 800, 1981Snapper LT11,2002 Kubota B7500HSD
My owners manual rates the B7500 at just under 16kw gross (21hp).
Why does the motor tag thats under the muffler, rate this engine at 17.5kw which is about 24 hp?
My dealer also said that I can indeed run a 5ft bush rotary mower as long as I keep my 302fel on for counterweight. I have no trouble with the bushhog squealer(high weeds/brush). Kubota underrates for safety, weightwise.
   / B7500 true hp?/mower width #2
Kubota uses that engine in other stuff and probably sells it also to outsiders--even a rumor JD has been looking into Kubota engines. The rating on the tag is for max design RPM, the govenor on your tractor essentilly derates your horsepower. Glueguy showed some graphs way back that show this. For example the engine used in the BX2200 puts out 22 horses at 3200RPM but when used in the larger and since eliminated deluxe B1700 (B1700--B2100--B2400 series) the engine was rated at 17 horses at 2600RPM--exact same engine!!!!!!!! I would not recommend messing with your tractor to get more RPM. J
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2003 CATERPILLAR 420D BACKHOE (A51242)
2003 CATERPILLAR...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
FUEL TANK (A50854)
FUEL TANK (A50854)
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
